What other fluids do I change and where?
I have flushed and changed:
Oil Trans brake steering cooling What other fluids do I change...and how/where do I do them? Thanks guys. Greg |
front diff gear oil - empty with the 17 or 21 or 22 or whatever size mm nut on bottom of diff and fill through the dipstick on passenger side of diff
rear diff gear oil - empty with a 1/2 inch drive to remove plug for bottom hole, fill with 1/2 inch drive through top hole. Remove top plug first (to make sure you can break it free before you drain it through bottom plug) Both plugs are on backside of rear diff.
Matt Locker Link 2015 BRZ Limited 6MT 92 Ebony LS-L ECUtune Stage2av1, Z32 MAF, 370cc injectors, TomsSVX intake, BontragerWorks 22mm RSB #003, HID Hi and Lo beams, OT endlink and bushing mods, PWR Aluminum radiator, Harvey's QC shift kit, 2.5" flowmaster 80 exhaust, 17" Michelin Pilot Sport A/S, Poly sway bar bushings, Slotted Bradi rotors, AFBeefcake powdercoated calipers, 97 grill, and a huge set of air horns. 300,000 miles and counting 92 Ebony LS-L. ecutune stage1v4, motorsport 1pc pulley. Garage Queen - sold to Dad in upstate NY 155,000 miles 19 Subaru Ascent Premium - -Hers !. 89 DL 4x4 little red wagon - a.k.a. The immortal suby. 275k R.I.P. Last edited by immortal_suby; 10-18-2006 at 07:24 PM. |
Front and rear diff??
For the front, use the drain plug at the front of the transmission. It is a 21 or 22 mm head. Then add new through the top like the ATF but on the passenger side. For the rear, there are two plugs that a 1/2" breaker bar will fit into. The bottom one is the drain, the top one is the fill. MAKE SURE THAT THE TOP ONE CAN BE REMOVED BEFORE YOU DRAIN WITH THE BOTTOM. Otherwise you will drian it and only be able to fill to the level of the bottom hole. edit: Damn, you beat me, but at least I got the size of the Front drain plug right ![]() ![]()
oh dont forget blinker
Thank you.
![]() Greg |
