fwd/awd fuse
While checking my a/c fuse, I noticed the fwd fuse was missing. I know this is OK because it should only be used in emergencies. However, the whole area looked fried. There were no prongs there to hold the fuse. I want this option in case the car ever has to be towed or I need FWD in some emergency. How do I repair/replace this fuse holder?
Michael 1994 Barcelona Red SVX-LSI Two-owner:169K 1995 Emerald Green SVX L AWD #80 - Custom intake w/cone filter 99K with killer stereo system 2002 Acura MDX-Touring Edition w/navigation 2008 Toyota Prius 1987 Mercedes Benz 560SL |
I have a partial answer - but admittedly not a good one. On my car the same thing was true as well as the A/C relay plugs were loose. What appears to have happened is the whole block in front of the main fuse block cracked, but I didn't know that until I started checking it out. I was able to push the block out of the holder through the bottom and open the block of contacts up. I used some silicon adhesive/caulk to hold the contacts in place, then put the assembly back into the holder.
For me the only right solution would be to acquire a whole new block and associated wiring. My way works but not very elegant. hope this helps, or somebody else chimes in. |
The slot for the FWD fuse has grease in it. It will be very discolored over time. Put a fuse in there and see if the FWD light comes on on your dash when you start it.
also, it won't help for towing
you'll still fry the diff if you try 2 wheel towing it when you have it in...
SV What? |
there is a non-conductive greese in there. This is used, i would imagine, to prevent something from falling in the slot and connecting the terminals.
Mike |
Chris SVX World Network Administrator -1993 Subaru SVX LS-L, Barcelona Red, #46, 160,000+ Miles (Sold to SomethingElse ![]() -2011 Toyota Sienna SE, Black, 30,000+ Miles (Swagger Wagon ![]() -2002 BMW R 1150R ABS, Black, 26,000+ Miles (Daily Driver ![]() SVX Owner from February 1997 to March 2008 SVX Online Community Member since February 1998 SVX World Network Member since February 2002, Member #520 Life is a game. Play to win. The world belongs to those who can laugh at it. |
Where exactly is the FWD fuse located at??? I've never really cared to take mine out of AWD..... But now that everyone is talking about thier block being fried I think that I will check mine to see if mine is messed up too... So where do I look????
2020 Subaru Outback Touring - Wife's first Subaru 2005 Volvo V70R - 5-cylinder love! :Heart: ** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned ** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!! ** SOLD ** ![]() |
fuse box under the hood, the fuse location is clearly labled, unless of course your fuse box label is gone.
Oh, cool... I've never had to look in the fuse box before..... Guess since I see my car so very little I just don't know all that much about that part of it....
