Old 04-22-2003, 01:52 PM
SVXamateur
Quick "5 speed" Question
To those of you with a 5-speed in your SVX.
Are you happy with it?
Has it given you any problems?
I need to know whatever you guys can tell me before I pop the question to smallcar.com
oh by the way it is a 1994 L SVX (Front wheel drive)
Thanks.
Adam Thompson
Old 04-22-2003, 02:56 PM
mbtoloczko's Avatar
sans SVX
no 5-speed for FWD SVX...
I don't think there is a 5 speed FWD Subaru tranny that will fit in a FWD SVX.
Mychailo
Visit my locker
Old 04-22-2003, 03:17 PM
Sure there is, My "Project car" is a 95 Impreza 2 door FWD 5-speed, the tranny out of it will bolt right up, the Legacy and Impreza line from 90-95 had a 5-speed FWD as standard equipment, but there are none that have a hyd. activated clutch, they are all cable activated.
And being a FWD will make it easier to do the swap, as you won't need to mess with the rear diff, nor lengthing the driveshaft.
You will for sure, be able to roast the front tires at will
And yes, I'm very happy with mine.
And no, it hasn't given me any problems.
Old 04-22-2003, 07:38 PM
SVXamateur
Thanks
thanks to both of you. It's appreciated
Old 04-22-2003, 07:53 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Welcome to the board btw
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 04-22-2003, 09:14 PM
Subafreak's Avatar
Superbeast
Ya I LIKED mine.
Old 04-23-2003, 01:59 PM
AutoTchr AutoTchr is offline
Very happy! The car now has more emphasis on sport, less on luxury to give you a realistic view. I went with the 4.11s.
Mike
ASE Master and L1 cert. Discounted Repairs
I feel a lot more like I do now then I did before.
92 SVX 5spd, (sold),92 SVX Teal, 67 Mustang 351C 5spd, 00 Galant.
