Front Camber Caster Plate Group Buy
SvxRide has been working with Kmac out of Australia to get SVX camber caster plates for a while now. I was working with Bill in getting them to fit his car a short while ago. Now that they have been installed and are known to be working very well, we would like to offer a group buy on them. The group buy is more or less a way to save on the costly shipping of individual units from AU.
Pictures: Sorry if they are slightly out of focus These strut mounts are VERY high quality and give the user adjust ability beyond what camber bolts can and make it so easy to do. Just jack up the front of the car, loosen (do not remove) the 3 studs. Adjust camber or caster to desired amount. re-torque the 3 studs... Thats it! these mounts are also much firmer than the stock rubbers, which in turn also increases suspension precision which can also help your constancy in handling. The Group buy pricing is $399+shipping from NJ for a pair of front mounts. Please feel free to ask any and all questions in this thread Tom |
Re: Front Camber Caster Plate Group Buy
I could use a pair.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
Ok. list starts.
1. Shotgunslade |
I would like to get at least 6 pairs to make the group buy go...
Tom |
hmmm, probably should add me to the list Tom
Down to none ![]() |
Ok I probably will
![]() 1. Shotgunslade 2. Wawazat?? 3. TomsSVX Tom |
YT,
We can provide the stage 2 or stage 3 kit at the advertised price. I'm running the stage 2 kit on my car and I'm not sure I'd recommend the stage 3 for anything other than dedicated track cars (Dan? ![]() -Bill ![]()
Why would you not recommend the stage 3 for anything less than a dedicated track car?
There is no rubber/urethane to dampen road inputs to the car (and you thought that Gruppe N mounts increased "noise"
![]() -Bill
1. Shotgunslade
2. Wawazat?? 3. TomsSVX 4. Sov13t ![]() -Sov13t. __________________ ![]() |
If only I had money
Need two more people to jump on this so we can place the order
Tom |
again... if my pearlie sells I am in....
Add two sets. One for me and one for my son.
Lee
If I do not get in with these 6 will I have to wait for another group of 6 to be put together?
