Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Supercharged Projects
Old 11-20-2006, 05:55 AM
mikecg's Avatar
mikecg mikecg is offline
Send a message via AIM to mikecg Send a message via Yahoo to mikecg
ECUTune Stage III dyno pull videos
For all those patently waiting, I now have the video's up on YouTube. here are the links. The S/C nearly drowns out Toms exhaust in the vids. Impressive when you consider that I was standing behind his car for one of them.
My dyno pull
Tom's Engine
Tom's from rear
Enjoy.....
Old 11-20-2006, 06:30 AM
thanks Mike, i love patently waiting
Old 11-20-2006, 06:52 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
YAYYYYY for videooo
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 11-20-2006, 07:25 AM
mikecg's Avatar
Whatever.......
Old 11-20-2006, 07:36 AM
sicksubie's Avatar
What are the #####'s?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 11-20-2006, 07:42 AM
check Mike's locker
Old 11-20-2006, 07:56 AM
mikecg's Avatar
With Software Version G, Toms best is 242HP and 275ft-lbs at the wheels with 12lbs boost.
My best with the same Version of software was 214HP and 236ft-lbs at the wheels with 9lbs.
Tom can probubly get another 20 to 30hp with a better exhaust and improved intake. I should also make a little more power after I fix some things. It appears that the changes in my A/F ratios and a slightly rough idle would indicate either a boost or vacuum leak. Or both. I plan on checking and sealing all my vacuum lines and replacing the intake gaskets. Then maybe I'll be trying it again. I'll get in touch with Tom to see if his exhaust is ready and if he wants to do some more pulls.
Old 11-20-2006, 08:16 AM
Mike, my pull before last was a little better... 247/280 I think... do we have that file??
Old 11-20-2006, 08:33 AM
mikecg's Avatar
Ya I have all the files with me. I show 2 pulls for each version of the software. If you ran a 3rd pull, he didnt give me the file. I posted Version G, because it was the one your running, and has the smoother curve. Here's your best pulls for the other versions.
Version 1 = 241hp, 280ft/lbs
Version F = 249hp, 274ft/lbs
For those trying to follow, these are peak numbers. The version G may make a touch less power and torque, but the power is much smoother and pulles evenly though the power band. The other versions have a couple of spots were the power falls off a little.
Old 11-20-2006, 08:46 AM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Send a message via AIM to Budfreak
Lookin good guys. Once I get mine done I'll try to join you for some dyno time in the future.
Old 11-20-2006, 11:53 AM
Tony117s's Avatar
Tony117s Tony117s is offline
Send a message via AIM to Tony117s Send a message via MSN to Tony117s
so assuming 25% drivetrain loss tom's svx has 308 hp. didn't lan dyno it and get like 340ish crank hp?
[B]Tony
'95 Polo Green SVX L AWD 62k
'05 Ebony Pearl GT LTD Cobb Stage 1, Tein Coilovers, GFB BOV, Pzeros 6k
'00 Green Forester S 78k
Old 11-20-2006, 11:57 AM
Earthworm's Avatar
Meow!
They think Tom needs to upgrade his exhaust.
Old 11-20-2006, 12:00 PM
mikecg's Avatar
LAN also used a different type of dyno. We ran a drum type by DynoJet. I really dont know which on is more exacted. My stock FWD tranny put down 179HP on the on LAN used. Dyno numbers are kind of tricky. You can get different numbers just by changing the dyno operator.
Old 11-20-2006, 12:32 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Thumbs up
To keep everything in one place, here are the resized dyno graphs for Mike's and Tom's best 'recorded' pulls.
Mikecg (9psi):
TomsSVX (12psi):
Nice videos Mike!
Chike
2006 Steel Gray WRX TR (sold)
Old 11-20-2006, 12:43 PM
hexadec0079's Avatar
hexadec0079 hexadec0079 is offline
Parts Breaker, Tire Waster
Send a message via AIM to hexadec0079
wow, you definately need an exhasut, stat.
Looks great though, I mean 300 crank HP is phenominal
1992 SVX- -Drivetrain by BUDFREAK-
Green, LS with spoiler, 157,000, ES Swaybar bushings, 9005/6 mod, 2.25' Dual Exhaust, Custom Grounding, Hyperwhite fogs, LED tails, 4.44s, custom Blitz intake, tranny cooler, thats about it, for now...
1997 Chevy 1500 -FOR SALE-
5.7 liter, Z71, 300hp+, still almost 20mpg
1986 Merkur XR4Ti -SOLD-
SVO Engine, T3 hybrid turbo, K&N, custom ducting, Initial D painted, 18psi, fastest car for under $1000, ever.
