VALVE COVER gasket installation
Please let me know if I should install the rubber/metal "washers" which go on the top part of the bolts that hold the valve covers on, DRY (no RTV or gasket sealer), or put on with RED or BLACK RTV? Also, should I use RTV on valve cover gaskets?
YOUR PROMPT REPLY would be greatly appreciated, since I will be installing the new gaskets tomorrow AM! THANKS! ![]() ![]()
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) ![]() ![]() |
I would replace the rubber/metal washer with the new valve cover gasket. They help apply an even pressure to the cover after the bolts are torqued. So yes to thaem by all means.
As for using RTV,,,, I would not if you are using a gasket. They were designed not to be used with rtv. If rtv was used before then you might have to if you can not clean up the cover enough. If you are replacing the valve cover gaskets then may I sugest replacing your spark plugs at this time. I might be easier in the long run. Steve
92 SVX AWD 130,000 w/ rebuilt SVX 4.11 ![]() 97 Audi A4 1.8T (Daily Driver) 03 Ford Expedition(hers) SVXepidia SVX information warehouse Are you in? My Old Locker A 4.11 Founding Father "Tranny #6" I really need a manual ![]() Reading IX [SIGPIC][/SIGPIC] Ya I was there
VALVE COVER oil leak
1) Yes, that's why I got new washers (also, I RTV'd the washers to the bolts when attempting the "Beav fix" [O-rings to create additional pressure between washer and bolt])
2) I hope I can hold gaskets in place while placing VC back in position without using any sealer. Thanks for this info also! 3) Don't think I can do today....got behind schedule....especially since my sprinklers won't shut off ...AT ALL!!!...joys of home ownership! THANKS AGAIN! ![]() P.S. Yes, I thot of doing sparks, but only 30 K on set I replaced at 60 K (odometer 90 K now)....which sparks BEST?
REMOVING VALVE COVER.....
Where is the post describing the removal of the valve cover in detail, including how to tip different ways in sequence to get the valve cover OUT after it is loosened.......PLEASE?
THANKS! ![]() ![]()
I pulled my air box out and the battery out, and once all the bolt were out, they came right out...which side are you having trouble with?
Huck Subaru Ambassador 92 SVX LS-Tour Magnaflow Exhaust, 5-Spd-AWD ![]() 88 XT6 AWD 5-Speed "Bride of FrankenWedge" 15 Impreza Premium Sedan 15 Crosstrek XV 5-Speed My 5-Speed "How-To" Write-up 1976 Pontiac Firebird Formula Current Count of Subaru's Owned.... "70" |
