Old 03-15-2003, 01:50 PM
petesvx2's Avatar
petesvx2 petesvx2 is offline
Lightbulb Changing Fog Lights
Whats the easiest way to get the fog lights out and in to replace them? My hands arent nimble enough to do it the way I was trying.
1992 Pearlie ... ??????k Sold 8/04
Kenwood KDC-MPV619
Wedgie Cupholder
1998 Acura Integra LS 74k Sold 1/07
2007 Toyota Tacoma Prerunner SR5 .04k!
2011 Toyota Tacoma Double Cab, 4x4 TRD Sport
Old 03-15-2003, 02:54 PM
CDG's Avatar
CDG CDG is offline
No front plate on My SVX
Send a message via MSN to CDG
take it to a shop
sorry you asked for the easiest way.
Chris G
92 Pearlie, sold @ ~209k miles. Now owned by Tim.
Current Ride, 1985 Honda Aero 80, stock 3024 klms
Old 03-15-2003, 04:44 PM
Old 03-15-2003, 09:41 PM
petesvx2's Avatar
Originally posted by CDG
take it to a shop
LOL good one...What I meant to say, how can I easily get my hand in there?
Kenwood KDC-MPV619
Wedgie Cupholder
Old 03-16-2003, 09:13 AM
BluebyU's Avatar
BluebyU BluebyU is offline
I'm just sayin'..........
There really isn't an easy way that I could find. Taking them out and replacing them would be the easiest. Would I do that? Nope!! When I changed mine to Piaa crysal ions, it was cold as crap outside. It must have taken me 45 minutes to change them. It takes patience lotus blossom......now if i could just get mine aimed right........
Bobby
'95 Laguna Blue Pearl SVX L AWD
'18 Kia Stinger GT Twin Turbo - Sunset Yellow
Old 03-18-2003, 11:05 AM
Earthworm's Avatar
Meow!
I know what you mean. My fogs are out of alignment compared to the headlights. The fogs only shine about 10 feet in front of the car. The bumper also cuts off the effectiveness of the fogs.
Old 03-18-2003, 11:11 AM
JLittell
Get a pair of needle nose pliers. Hold in place and snap the wire into place. Took me 3 minutes.
Old 03-18-2003, 11:15 AM
Looks like you need to do a "How To" with pictures!
Old 03-18-2003, 11:18 AM
JLittell
Different strokes for different folks!
Old 03-18-2003, 12:05 PM
kuoh kuoh is offline
I don't believe they are out of alignment. Fog lights are an exercise in compromise between light penetration and backscatter. They are not designed to project anywhere near as far as the low beams. Because fog is very effective at scattering light, they are only designed to provide improved closeup lighting. You are supposed to slow down anyway in heavy fog.
As for their location, having them below the bumper would not improve their lighting distance. It could however reduce back scattering due to the bumper cutting off stray light rays that might have otherwise headed up to be reflected back to the driver.
Unfortunately, many drivers use them as supplements to the low beams and some even adjust their aim to match, much to the dismay of other drivers. Whenever I see a car with fog lights that are more blinding than the low beams, I wish my car had "light" seeking missles.
KuoH
Old 03-18-2003, 01:39 PM
Earthworm's Avatar
Meow!
I agree 100%
My fog lights are still out of alignment. The dims are level but one fog is noticibly lower than the other.
Old 03-18-2003, 02:54 PM
BluebyU's Avatar
I'm actually happy with the light that my fogs emit, however, my driver's side fog light shines directly into the eyes of oncoming traffic and needs to be aimed downward just a bit. I've been on the receiving end of their light and it's not fun. I'm told the only way to adjust them is to take the headlight off the car, and i'm not too inclined to do that as I might break something......lol....
Bobby
Old 03-18-2003, 03:11 PM
Unless the bulb is incorrectly seated, I don't think there is a way to adjust the aim of the fog lights independently from the other lights. The aiming assembly in the SVX adjust the entire unit.
KuoH
Old 03-18-2003, 03:15 PM
JLittell
I don't think the fogs are adjustable.
Old 03-18-2003, 03:24 PM
KuoH
The stock H3 bulbs are impiossible to seat incorrectly. They only go in one way and the metal spring clip which holds the bulb in and provides the ground will not fasten under the notch if the bulb is not seated 100%. The whole assembly adjusts as a unit, there are no individual adjustments for just the fog lights.
I recently replaced all my bulbs across the front with the PIAA Platinums. The easiest way for me is to pop out the corner lights and grille, take the 4 bolts out that hold each assembly in place, unplug the connectors and remove the assembly. Total time for removal of both headlight assemblies, bulb replacement (6) and reinstall should be no more than 20 minutes total.
