Old 05-14-2006, 02:30 PM
Andy's Avatar
Andy Andy is offline
Send a message via Skype™ to Andy
Water Power
To good to be true?
LINKEY
Andy
If I would be a young man again and had to decide how to make my living, I
would not try to become a scientist or scholar or teacher. I would rather
choose to be a plumber or a peddler in the hope to find that modest degree
of independence still available under present circumstances.
-- Albert Einstein, The Reporter, November 18 1954
Old 05-14-2006, 06:02 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
hummm the only problem with that is where is the energy coming from to convert the water in to HHO gas to run in the car? the engine?
- John
Old 05-14-2006, 06:54 PM
Weebitob Weebitob is offline
The Kind of Casual SVXer
Send a message via AIM to Weebitob
Either the engine is a traditional natural gas with pre-converted HHO gas in the tank or they put their special electrolysis machine in the trunk attached to a water tank with the HHO being fed straight to the engine.
However, 100 miles on 4 ounces I would figure a compound like that would burn a whole lot faster unless it is being injected into the engine in really slow intervals. I wonder if they evered dynoed it or released the results on what its hp rating and lbs of torque it exerts?
And another thing, I wonder how this technology would impact humanity as well as the entire enviroment in the distant future if used on a large scale?
Old 05-14-2006, 08:39 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
I really want to believe this. But it just falls too close to that too good to be true category. Where is the conversion process? How much electricity does this technology use?
Please be a reliable source of energy, and the ability to use tap water.
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 05-14-2006, 09:45 PM
I am not so sure about reliability but what I am sure of is it probably uses highly filtered water in order to avoid impurities that. But I wonder if Heavy Water is more effective or would isotopes not disimilate into hydrogen quick enough to be effect. So can anyone read this on Heavy Water and tell me if you can get hydrogen as a result of breaking down Deuterium, ecspecially look under Fractional Distilation?
Old 05-14-2006, 10:08 PM
The biggest thing I got from that article, (besides the pop ups. ) is in the last 3 paragraphs. Only 5 countries have plants that produce heavy water, some of those have closed down, and the most popular way of producing it is similar to the way brandy is distilled from wine.
Sounds like it would be extremely expensive, and the article also says it is a "controlled" product, so the availability to us common folks isn't going to happen without the re-emergence of a Waco scenario. (Behold! I have 3 underaged wives and a quart of heavy water. I summon thee to carpool in my hybrid! )
Informative! It also makes me think about all those camping brochures that says to boil water excessively before drinking.
Robert
Old 05-14-2006, 11:28 PM
Suby Fan's Avatar
another thing is hasent HHO all ready been proven impratical?
- John
Old 05-14-2006, 11:36 PM
No, it just hasn't proven practical.
Old 05-15-2006, 02:06 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
I am not a chemist, but I don't see any advantage in using heavy water for this application. A given mass of heavy water would contain less hydrogen atoms than the same mass of ordinary water.
Regarding water as a fuel, it is undoubtedly the best way to go, but there are two problems:
Firstly, separating the hydrogen and oxygen requires a lot of energy - more energy than you will get back from burning it (due to less than 100% efficiency). This is why car manufacturers are researching fuel cells which use the water more efficiently than combustion engines.
Secondly, the economic reason. Any companies that develop this technology will ensure that you will never be able to fill up your car up from your garden hose. If and when water powered cars are available, they will make sure that you have to buy special water at premium prices.
100 miles in 4 ounces doesn't sound right. According to a search, Hydrogen contains 2.8 times as much energy as gasoline. But water is only 11.2% hydrogen by mass. So 4 ounces of water is at best equivalent to 1.25 ounces of gasoline.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
