Help! I cannot locate rear strut mounts for my 1994 SVX, Can anyone offer some help!
Re: needed rear strut mounts & struts for a 1994 SVX
At this point I believe its cheaper and easier to buy coil overs for the car, they should ride as well as stock with better performance and they can be had for cheaper (assuming you can find them) then oem struts and top mounts.
check this link - they do come up from time to time ....
https://www.jauce.com/search/subaru+svx
there is a 4WS SVX being parted out - it has OEM shocks and the top hats look clean each shock is approx US$45each https://www.jauce.com/user/upjpn17?&...x&n=100&page=1
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. Last edited by SURTEESS; 03-17-2021 at 01:16 PM. |
