Old 11-10-2014, 12:52 PM
Balthazar Balthazar is offline
Unhappy How long does my trans have?
so here is the rub,
I bought this 92 LSL a few months back it has 176k it was beat to **** mechanically and on the exterior by the PO the interior is in great shape however .. anyway, back to the matter at hand.
The transmission has a shudder/vibration around 1900-2400k rpm it feels like in every gear, but in 3rd and 4th you really feel it. Also very occasionally the shift between 2-3 slips and i do get the very occasional bang going into reverse this mostly happens when going from drive to reverse like on a 3 point turn and yes i was fully stopped before the shift.
I also get a strange surging when taking off when cold on a right turn at anything below 1/2 throttle. I'm not sure if its related or if my MAF just needs a good cleaning and or re-soldering
The service records indicate that the trans was rebuilt about 50k ago. I still wanted to service the trans because the fluid looked dark. so when i dropped the pan this is what i found..
That magnet is looking pretty damn fuzzy and those chunks sitting next to it are pretty damn big... what i didn't snap a pic of was the bolt that was laying in the bottom of the pan as well, It was one of the bolts that go through the filter
so i installed a new filter and filled her up with some max life and a bottle of lubeguard red it feels a little smoother but is still vibrating. I did remove the Subaru added external filter as it was leaking and rusty i figured it was probably running in bypass mode anyway.
is there anything else i can do to prolong the life of this trans? is it worth adding a external cooler and filter? or should i just save money for a 4.44 swap?
Old 11-10-2014, 01:35 PM
Cotton's Avatar
Cotton Cotton is offline
Some Random Weirdo
Re: How long does my trans have?
Do the 4.44 swap. I put a secondary trans in it and it went 2 years later. Some people get lucky and others don't. I should have done the 4.44 the first time instead of wasting my money on a used trans that has major issues to begin with.
Old 11-11-2014, 09:05 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
A used trans is always a used one. Based on my personal experience, rebuild the 4.44 trans before you install it.
The bang you hear in reverse can be a worn drive shaft U-joint.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
