Old 02-02-2016, 03:11 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Headlight reflector removals
I have a spare set of heatlights that I have heat opened - leaving the glass fronts seperate.
I want to know how to remove the "guts" in order to send the rear plastic sections to someone who needs them.
(I want to use the hi/low beams on another project).
Thanks
