Old 09-02-2015, 06:20 PM
Numbchux Numbchux is offline
Anyone replaced ECU pins?
I'm working on another EG33 swap. This one has had several people working on it, and the harness is a bit of a mess.
At one point, someone removed all the pins from the ECU connectors that they thought wouldn't be necessary......VSS, CEL, Test/Read mode....you know, the ones you would have no use for
It looks like they did it correctly, and didn't damage the plastic connector, but I still probably have to replace them. Anyone found a source for new pins that will work in the ECU connectors (the smaller of the 2 pin sizes)? Any recommendations for getting the pins out in-tact?
Old 09-15-2015, 11:01 AM
SubaruPartsGirl SubaruPartsGirl is offline
Parts Hook-Up
Re: Anyone replaced ECU pins?
Subaru dealers do have access to some pins. We have a kit out in the shop that may have been complete at one point but now it's basically a box with a couple of pin connectors thrown about. If you can send me a picture of the pins you are looking for or some specific sizing I may be able to produce them.
Reply to e-mail... jackie.whetzler@annapolissubaru.com
Jackie
Annapolis Subaru
149 Old Solomon's Island Rd
Annapolis, MD 21401
443-837-1422
www.AnnapolisSubaru.com
Jackie.Whetzler@AnnapolisSubaru.com
Old 09-15-2015, 12:25 PM
PhyrraM PhyrraM is offline
http://www.mouser.com/ProductDetail/...liN80oxFE3h5Jy
That is close, but might not be the same one.
They are from AMP (now TE Connectivity), multilock series.
I would search "TE multilock" on Mouser or other electronics sites, download a bunch of related Data Sheets, and then sit down with calipers or a very precision ruler and find the ones you need.
Check out this page:
http://www.mouser.com/TE-Connectivit...Z1ehb5Z1yq277r
The right stuff is bound to be in that list...somewhere. Also, a lot of the differences are material and coating, so there may be multiple part numbers that work.
Another one that is likely to work:
http://www.digikey.com/catalog/en/pa...0-series/27077
Old 09-15-2015, 01:40 PM
Parts Hook-Up
That is a really nice site, first I have seen it although I can't say I look for this often. I will let other customer know about it! Those small connector pieces with a short length of wire in various sizes are what we have here. You can't get the plastic plug housing from Subaru, just the little wire ends/pins.
Jackie
Annapolis Subaru
Annapolis, MD 21401
443-837-1422
