horn
ok my horn does not work. i have checked the fuse and the horn itself and changed the horn relay and still no horn can anyone help.
Re: horn
It could be a loose connection or a broken clockspring. Does your cruise work? Airbag light?
Re: horn
air bag light has been on since i have own the car (6 yrs) i dont remeber if my cruise works or not. what is a clockspring?
Re: horn
TRY GOOGLE!
Re: horn
It's called that because it simply looks like a clock spring that winds and unwinds. This is how a positive electrical connection is made to the airbag and still be able to turn the wheel back and forth. The horn and cruise control circuits on the steering wheel run through this clock spring. Check to see if the horn and cruise are working. If not, you probably need to replace the clock spring. Quote:
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 12-01-2010 at 12:20 PM. |
Re: horn
Exactly what i mean by TRY GOOGLE! - You cut out all these back and forth replies,and get your answers direct! |
Re: horn
![]() Harvey.
Re: horn
my cruise control does not work. so from what i read the clocksping is bad right.
Re: horn
where can i get the clock spring
Re: horn
Re: horn
so what you are saying to strip the greeen and black wire and ground it .right
Re: horn
![]() Harvey.
Re: horn
thank you for the info i will try that and get back to you. and the relay is new.
Re: horn
ok i did what you said and grounded the wire(green wire with black stripe and the horn sounded. so im to understand that it is the clock spring. right.
Re: horn
