A few annoying problems I want to fix:
My trip meter does not work apparently. Odo works fine. The button for the trip meter feels "funny". The car used to have white gauges that I removed. I dont remember if they worked before that. Suggestions to fix? Can I replace just the trip meter? I have a donor car.
The car has Drilled/Slotted rotors all the way around. Under hard breaking I notice a low "wwssshhhh" sound, for lack of a better term. There doesnt seem to be any warping. Pads are fine. No squeel. Is this the nature of this kind of rotor? There is rust forming on both sides behind the rear wheel. Isn't there some drainage tube that gets clogged and causes this or something? I had more questions...but I forgot them... I'll be back with them later.. ![]()
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN! |
Try "Flicking" the trip button, and holding it in, then letting it "flip" back out by slipping your fingernail off it to th eside...got mine to start working again on my old pearly that way. I don't have slotted and drilled rotors, so I'll hold off on any comments on that... As for the rust, you just have to make sure you spray back up around th einside of the wheel well, to rinse out all the grime and road salt that can build up in there....a automatic car wash will NOT clean this out. But if there is already rust there, there's no avoiding it now, and body work will be needed to stop it.
Huck Subaru Ambassador 92 SVX LS-Tour Magnaflow Exhaust, 5-Spd-AWD ![]() 88 XT6 AWD 5-Speed "Bride of FrankenWedge" 15 Impreza Premium Sedan 15 Crosstrek XV 5-Speed My 5-Speed "How-To" Write-up 1976 Pontiac Firebird Formula Current Count of Subaru's Owned.... "70" |
I also have this EXTREMELY ANNOYING whistle when ever I use my Heater in the car. any speed. Though its volume changes w/ the speed (low med high)
Suggestions to fix? its so annoying...
Pull the heater motor out and oil it....it's kind of behind the glovebox..
Actually the motor can be oiled without removal. The bottom cover is held on with 2 screws. Remove the cover, clean out all the junk, put a few drops of oil in the cover (there's a gauze in the cap that holds it) then replace the cover.
The brushes eventually wore out on mine and I had someone cut new brushes to fit. Working great ever since.
...Ok. could you better describe the motor location?
Flicking the Trip didnt work.
all slotted rotors whistle when coming to a stop its just the heat pockets in the slots being built up and releasing
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts -
![]() [SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not ![]() Member #995 ![]() Catch you next at: ? Auto-X ? |
-Pavan Last edited by pavanbabut; 03-26-2006 at 01:26 AM. |
hmmm. I tried prying it away, and it won't come off. How hard is it supposed to be?
James
I have all the problems you listed except the rusy one.
my trip meter, I just drive and jiggle and mess around with the knob for it untill it actually starts working The air conditioning whistle...I think is probly a misaligned duct thats leaking (and whistling at the same time ) The drilled and slotted rotors are suposed to make that funny noise
our vents are loud when you are running them at high speed, thts just the noise of air I beleive. The noise we are talking about is the whistling noise which you can clearly hear from under the passenger locker area and the pitch changes according to the speed you select. I am not sure if you are talking about this noise or the vent noise but just want to be sure about the type of noise. ![]() good luck, -Pavan |
