What is this?
Well I hope I can give an accurate enough description since I don't have a camera.
There is a small approx 1/4 inch diameter hose that goes into the backside of the intake manifold on the drivers side. Can someone tell me what this is, and what it is for? I accidentally broke it, it was pretty brittle so I needed to replace it anyways
-Hump '99 RBP Subaru Impreza 2.5RS '92 Pearl White Subaru SVX - 136k - My first SVX -traded '92 Yellow Subaru SVX LS "Bert" - 123k -The first SVX Convertible '92 Orange Subaru SVX LS-L "Ernie" - 139k -The first SVVVVVVX (stretched SVX limousine) Okay, so the bottom two cars don't actually exist but what if????? |
check your hood. it should have the vaccum diagrams on it.
SVXT6 (Pearly) just got running 201,000 (body) 105,000 (engine) Honda FT500 Ascot [Red] |
There's two out of the throttle body, and one out of the manifold. Check the diagram here: http://serial.cc/vacuum.jpg
That should give you a good idea of what your looking at.
Thanks a lot! that diagram was very helpful, it was the hose to the pressure regulator. Out of curiosity, where did you get the diagram? Is there a good website link with more diagrams? I had searched the How-To docs before i originally posted.
Download what you need.
92 SVX LS Pearl 94 SVX LSi Barcelona Red 82 Brat 4WD Bob |
Yup, the vaccuum line diagrams are under MISC - M - Vacuum Diagrams.
Note, many of the schematics, diagrams, and instructions are not just for the svx, but the loyale, justy, legacy, xt, and xt6, so if it doesn't look right, make sure your looking at the info for the correct car.
great! thanks again guys
The pressure regulator is on the other side (pass side)... You are thinking of the brake booster line?? Thats not just a hose, it has a check valve in it and is probobly a special order from subaru
Tom |
