i put an 2wd trans on my blue car
it won't move, can it be the trans computer, any one got a 2wd trans computer???
Are you sure you had the torque converter seated all the way when you were installing it? Did it POP as you tightened the bellhousing bolt down?....if it did, you broke the pump....this is bad, as the tranny has to be taken apart to fix it. This is a very common happening if you don't do Subaru trannys often. Hope that's not it, but probably is. Make sure it's full of fluid, as it takes a bit to fill the torque converter...
huck do you have a number i came reach u at please?
pm please with a number thank you.
