Anyone know about the camber kits being offered on eBay?
http://cgi.ebay.com/ebaymotors/ws/eB...ADME:B:SS:MT:1 I'm wondering if they're designed specifically for the SVX or just a hack mod from existing kits. Thanks in advance for everyone's feedback. -Bill
With my front springs in your car, you probably will not need a camber kit with the front, but it will be right at the limit. The range with the stock front camber bolts and my springs is about -1.4 deg to -0.8 deg. -0.8 is an ok number. The stock nominal spec is -0.4 deg. Our cars don't need to dial in a huge amount of camber in the front because our cars have a large amount of caster (much more than most cars) which automatically builds in camber as the steering wheel is turned. You'll want to put some camber bolts in the rear though. The ones I have in my car are this brand: http://www.specprod.com/ The part# is 81260 You can get them at many alignment shops for about $25-$30. I've had no problems with mine. Simple to install and easy to use.
Mychailo, thanks...so your suggested "rat tail file" mod will cover me for the front end? -Bill
Mychailo,
thanks! -Bill (noting that he needs to brush up on his "alignment speak")
Mychailo, I have to say that you're pretty knowledgeable when it comes to the SVX moreorless in the suspension dept! Thanks for all your input and helpful advice!!..Oh yeah, Porter is good one to refer too!
With my suspension setup I am running about 1.5 degrees negative camber in the front, and about 1.2 degrees negative in the rear. 0 toe front and rear, ride height roughly stock. Maybe slightly higher than stock in the rear.
It is extremely neutral (slight understeer) on corner entry and mid-corner, and I can put the tail out slightly on corner exit under power. ![]() |
How long (miles) have you been running with this set up? How are the tires wearing? Thanks. -Bill
that particular Ebay kit wont work or
fit the SVX, and one day they will find out if someone actually buys a set and ends up returning them.
The best and only kits I know of are as easy as replacing one of the lower strut bolts with a camber offset bolt. Done correctly with no grinding, cutting etc.... http://store.yahoo.com/svx-motorspor...ncambolki.html
My mom will forever live in me and never be forgotten, one day Ill see her again CLICK the LINK below to Visit the SVX Store: http://www.planetsvx.com http://www.motorsportwarehouse.com/svx/sig2.jpg Cars in the garage: 92 Toyota Soarer Single Turbo JDM RHD 70 Boss 302 Mustang 39k original miles 97 SVX Lsi 92 Liquid Silver Murano-ized (1st of its kind) 71 Cougar Xr7 Conv 351c 4v 4spd 69 SS Camaro 350 71 Nissan RHD Fairlady Z 70 Stang Fastback 70 Amc AMX 390 71 240z 89 Conquest TSi w/ 5.0 v8 swap 84 Mustang GT Turbo conv "good, if it bleeds, we can kill it ....." |
