Old 12-14-2008, 10:34 AM
taylorbr's Avatar
taylorbr taylorbr is offline
Moonroof Tilt Problem
Hi all, just got the SVX back to my place so I'm starting on the maintenance items. I noticed that the moonroof isn't tilting (when you first hit the open moonroof switch). To get the moonroof to open I need to hit the switch for a few seconds, then push up with my hand to tilt the moonroof, then I can hit the switch again and it will open just fine. Closing the moonroof works fine throughout the entire range.
Because closing works fine I think all the motors and gears are ok, so I am thinking that it must be a spring or piston that helps the moonroof tilt that is worn. Do you all agree? What would be the best way to gain access to this assembly to check? Thanks!
'93 Legacy LS (will last longer than the cockroaches)
'94 SVX LSi
Old 12-14-2008, 10:39 AM
Sir. Nate's Avatar
Sir. Nate Sir. Nate is offline
SVXtreme
Re: Moonroof Tilt Problem
mine gets stuck sometimes too.
-Nate
'92 LS-L Pearlie
Old 12-14-2008, 11:28 AM
siceclipse's Avatar
siceclipse siceclipse is offline
tjis is just an all out common problem with our cars
Mike
1992 SVX LS-L Pearl White 102,000 miles (Gone)
2005 Evolution 8 SSL Tarmac Black (new daily)
1995 Eclipse GSX Durango Copper Pearl (teh beast)
276awhp/280awtq @ 18psi (560's inj)
260awhp/260awtq @ 17psi (stock inj)
Old 12-14-2008, 11:57 AM
SuberNatural SuberNatural is offline
Mine used to get stuck, then i sprayed all the rubber gaskets with silicone. Now it works really well.
Aside from the fact that the initial press of the button doesnt move the sunroof. I have to hit the button, let go and hit it again and it pops up and slides back.
Then when i go to close it, it stops halfway closed. then i have to stop and start again. Makes me feel like the cables slipped and maybe something is out of sync.
1992 Liquid Silver/Black LSL
LeveL10 Stage 3 Trans and associated stuff
Old 12-14-2008, 12:10 PM
taylorbr's Avatar
FYI - it's supposed to stop halfway closed, so it sounds like yours is working correctly. The initial press of the open button should tilt it and stop, then you have to hit it again to slide back.
I'll try spraying the moonroof and see if that frees it up.
'94 SVX LSi
Old 12-14-2008, 12:38 PM
taylorbr's Avatar
OK de-gunked and sprayed with liberal amounts of silicone and now it works great
'94 SVX LSi
Old 12-14-2008, 02:10 PM
Glad I could help you out!
Any ideas on how to fix the initial tilt issue?
Old 12-14-2008, 06:52 PM
taylorbr's Avatar
De-gunking it worked for me, so I think that was the problem.
'94 SVX LSi
Old 12-14-2008, 07:25 PM
Ya, i de-gunked mine over the summer and re-applied lithium grease as suggested and it never got me anywhere. The only thing that worked was the silicone spray on the seals.
I feel like my cable just doesnt have the grip. Maybe i should figure out how to take the whole thing apart.
Old 12-15-2008, 10:16 PM
Francis Francis is offline
as for myself i had the same problem...i removed some dirty grease and applied some sillicone lube . now its all good
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008"
rest in pieces
Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill
Old 12-15-2008, 10:42 PM
Hondasucks's Avatar
Subaru Technician
I think there is a clutch in the motor unit that can be adjusted, at least that's another thing I've read about. Subarus must just have crappy sunroofs, since the sunroof in my Legacy and the one in my wife's legacy don't work most of the time, except they flat out don't do anything and then one day you'll hit the button and it will open, and then it's a crapshoot whether or not it will close, and sometimes I end up having to manually crank it shut.
1986 VW Jetta
Old 12-16-2008, 06:28 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
I've had this problem as well and I have just been ignoring it. Since this this was posted yesterday, I decided to go outside after work and check on my sun roof in the cold night.. I saw there is a lot of random bits of mess all through my track of my sunroof.. Thanks for posting a solution!
It's a sunroof right? Moonroof's are more twards the back of the car..
Old 12-16-2008, 06:41 AM
Yes ours is a sunroof. A moonroof is one that has a piece that slides back so that you can have the sun come through the glass piece. On the moonroof the glass piece then can be opened up to allow air in.
Old 12-16-2008, 08:34 PM
Hondasucks's Avatar
Subaru Technician
moonroof = glass, sunroof = solid
(although the buttons on my 86 GL-10 sedan are labeled "SUNROOF")
1986 VW Jetta
Old 12-17-2008, 05:42 AM
subbieatnz's Avatar
subbieatnz subbieatnz is offline
Sweets i was going to ask same question lol. Ive got same prob. i didnt clean it but i regreased it. worked fine with out pushing it up once. I shall try the silicon on the rubber seal next
1992 NZDM SVX Maroonish Red/Black ( 1st car ive owned with an cd player ) Has been retired
1989 Vortex 6 Maroon
1983 RX Silver Grey
1973 1400 GSR Yelo 2 Door Coupe awaiting Restoration
