Old 09-04-2008, 11:11 AM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
5/6mt and rw drive ?s
ive seen a few SVX's on youtube that have rear wheel drive and 5/6mt
im lookin to do the same cause i think it'll be awsome
im starting to save up for the transplant but i need to kno what it'll all take parts wise and how much it'll cost roughly
-tranny is roughly 3k right?
also thinking about turbo...any ideas on that too
i kno a turbo from motor-sport cost about 4k but how hard is it to put in?
btw, i hav a fwd....
thnx
Old 09-04-2008, 12:12 PM
mikecg's Avatar
mikecg mikecg is offline
Send a message via AIM to mikecg Send a message via Yahoo to mikecg
Re: 5/6mt and rw drive ?s
I don't know of anyone on here that has done anything like that. But I can give you some info that will help you along the way.
Mine was also a FWD. I had TomSVX help me out with converting it to a 6-speed AWD. It is mostly the same as converting the Auto to stick with a few minor extras. Your rear subframe will need to be swapped out with one from and AWD. Your FWD doesnt have all the mounting points for the rear diff. and you'll need rear safts and a drive shaft. The STi rears will work with your factor rear hubs and a stock AWD SVX drive shaft will work with the 6-speed.
As far as RWD goes, the 6-speed STi tranny will need to be modified. Look at the STi drifters. I beleive Rhys Millen's company RMRProducts built STi's and the EVO's. Going RWD I would devenitly go with the 6-speed over the 5-speed, because of the strength.
TomSVX can also give you alot of info. He has done quite a few 5-speed and 6-speed conversions.
Old 09-04-2008, 03:13 PM
Mensaf's Avatar
Mensaf Mensaf is offline
What do you mean wrong SVX?
Don't plan on it less you can source some large rear parts. You'll need a stronger driveshaft, a strong rear (skyline is preferred. Easy to find since a lot of 240 owners swap those rears in too, but the fab work is a lot to mount it), and axles.You're basically first converting to awd, and then to rwd. You'll be sending all, rather than half, of the power to the rear axles, so you'll have to effectivly do the same mods as an STI would need if it made double the hp.
Old 09-05-2008, 03:57 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
I'm just curious why you would want to downgrade from 4WD to RWD? You want less traction?
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 09-05-2008, 04:12 AM
Mensaf's Avatar
RWD>AWD. More fun, and in the dry, more traction (except of the line) than AWD. Of course, a RWD conversion has quite a few things that would be unpredictable until you actually experimented after the swap, since the suspension layout and various beams/bars are all made for an AWD car.
Old 09-05-2008, 08:35 AM
VICSVX's Avatar
Never Forget
ok, thanks
i'll look into that company and see how that all goes
and im not going AWD to RWD, im goin to FWD to RWD
it wud be more fun to drive and it would be way different
my friend owns his own fab shop so he could help with the mods and all else that would be needed and ive been looking at 6sp too
again, thnx for all your pointers
Old 09-05-2008, 08:56 AM
Mensaf's Avatar
Originally Posted by VICSVX View Post
ok, thanks
If you plan on using the EG33, you don't have a choice but to do a rwd conversion via an awd swap. If you want to drop in an LSx motor, that's a different story.
Old 09-05-2008, 08:58 AM
mikecg's Avatar
The STi rear wont have any trouble handling all the power. I'm putting 70% of my power to the rear with a supercharger on the engine increasing my power output. The R180's are handling the power from 600+ horsepower STi's It shouldn't have any trouble with everything an EG33 can put out.
Old 09-05-2008, 09:04 AM
Mensaf's Avatar
The 450hp RWD STI's have broken STI R180's after a few runs. He said he wants to turbo the EG33. I'm gonna go out on a limb and say that a boosted EG33 makes more tq than an EJ25.
On a side note, what are you putting down?
Old 09-05-2008, 09:39 AM
Sov13t's Avatar
Sov13t Sov13t is offline
Electronic Counter Measures ON
Send a message via ICQ to Sov13t Send a message via AIM to Sov13t Send a message via MSN to Sov13t
I would put my money on our drive shafts going way before the R180 goes...
imho... converting to 100% RWD is not worth it with our cars... as Omar pointed it out.... you are pretty much converting to AWD then to RWD... cost effectiveness vs rewards of such a move are... slim to say the least.
I would get a DCCD controller for the 6spd if I were you....
-Sov13t.
Subaru SVX 94' Laguna Blue - 8.5 C/R Built Motor, 6spd
Old 09-05-2008, 10:01 AM
sicksubie's Avatar
-Sov13t.
Badda bing..... RWD on a SVX = dumb
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 09-05-2008, 10:40 AM
dcarrb dcarrb is offline
"More fun" = Burnouts in the McDonald's parking lot on Friday night, dude.
dcb
Old 09-05-2008, 11:43 AM
JaySVX's Avatar
JaySVX JaySVX is offline
First, you'll need to convert from FWD to AWD. To do that, you'll need the whole rear subframe, wheel hubs, a driveshaft, awd tranny, and i believe gas tank. $$$. Then, you'll need to lock the center diff, and disconnect the front diff. Time + money. Want to turbo? Drop your engine. It's easier. Check to make sure your engine can handle low boost turbo, ~9-12psi. Check compression, seals, rings, gaskets, etc. Then, fab up some fancy intake and exhaust to accomidate the turbo. Run oil lines, etc. Tom sells a sweet kit for 5/6speed swap that makes it a ton easier. Many users highly reccomend it.
Then, make your way to your local McD's, do a smoky burnout as the cop turns hte corner, pulls you over, arrests you, confiscates your car, and uses it in "demonstrations" when they show little kids how drinking and driving can cause accidents.
Also, be sure to turn your head to 120* off center from your head. It shows how serious you are.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 09-05-2008, 12:58 PM
-Sov13t.
agreed 100%. A 6mt w/ a DCCD cotroller makes the car essentially RWD with the controller off and you can adjust from there just how uch you want to engage the AWD. Thats what I have... I can spin the tires on demand when I want to and I can lock to 50/50 when I a racing.
Old 09-05-2008, 04:30 PM
Mensaf's Avatar
dcb
I was really thinking more of going to drift nights @ E-town the last Weds of every month.
