Will this headunit fit?
http://www.crutchfield.com/App/Produ...BB&c=3&tp=5684
Crutchfield says no...depth is only 6.1", factory radio is 6.625". DIN mount. I wonder about the center knob, will it clear the cover? Like the built in bluetooth, CT is a "hands free only" cell phone in car state. I also like the 728 colors, should find one close to the SVXs dashlight color... Anyone seen or tried one of these?
![]() 1997 Ebony #308 113k "The Black Diva"SOLD ![]() 1992 Black over Liquid Silver 152k SOLD ![]() 1992 Ebony 251k 444 SOLD ![]() 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k Last edited by processengr; 06-10-2008 at 10:49 AM. Reason: spelling |
This radio fits any din slot right? cause if that is the case it will fit and all you would have to do is find a universal pocket to put in place of where the factory cd player is...
ha!
I thought it was 6.25... even better ![]() Either way, you should be good on the back end, but you'll probably have to pull the curved liner off of the door to accomodate the knob in the front... unless you mount the unit on the bottom or mod the liner/insert ...who knows? it may even clear the knob, but I would go with melting the liner a bit (if needed) and keeping the head unit on the top side.
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts -
![]() [SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not ![]() Member #995 ![]() Catch you next at: ? Auto-X ? |
Re: Will this headunit fit?
Looks like it'll clear easy.
Just mount it up top as far as it can go, and your little knob should even clear the door. You shoudn't even have to pull of the plastic inside the hide-away door - looks to be a 1-1/2 DIN size. As far as the websites go, they're clueless about our cars. Crutchfield and Best Buy told me "It won't fit". I said "You're wrong". Guess who has a DVD player in their car? ![]()
-Craig 94 LSi 5spd Barcelona Red, 14Xk miles. Full custom exhaust (Stebro cat-back, custom rest of the way forward) 8000K HID kit from Tom (SVXfiles), Energy Suspension front sway bar bushings, Non-Droopy visors, Race Concepts C/D + Dimpled Rotors, Axxis Ultimate pads,SS brake lines, Bontrager Works #009 (or something like that), stripped interior. (up next) Full cage, fuel cell, 327 swap Last edited by ridered777; 06-18-2008 at 06:42 AM. |
The unit is installed, and fit excellent. I used the dc.svx wiring adapter and excellent instructions. ![]() I want to modify the liner to fit, but don't want to wreck it...what is the method to melt the knob clearance in? If I were to heat a metal rod of a slightly larger diameter than the knob and press it into the liner, I would fear that the plastic would stick to the rod and leave an unsightly finish... ![]()
![]() 1997 Ebony #308 113k "The Black Diva"SOLD ![]() 1992 Black over Liquid Silver 152k SOLD ![]() 1992 Ebony 251k 444 SOLD ![]() 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
