Need clean lug nuts
I need at least 5 to replace the locks and one lost one. I could probably use more to replace unsightly rusted ones.
Re: Need clean lug nuts
Are you looking for OEM lugs or just replacements? Why not buy a complete set for all 4 wheels. They range in price from $15-100 depending on what you want. What you need is 12x1.25 iirc
Sam Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners My Locker |
OEM or mechanically identical.
They look perfect. I would check the specs they give in the ad just to be 100% sure.
Good find and let us know if they work out. |
I have a set of 20 OEM lug nuts I'd sell for $20 shipped. Might have two sets actually.
