Leaking coolant line
Last Tuesday on my way to work my car overheated. My co-worker found coolant leaking out of a hose under the manifold on the passenger side. I don't think I can replace it without removing the manifold. I want to replace all old/hardened hoses so this doesn't happen again. Do you have to remove the manifold to do this. I would like to avoid paying someone else to do it if possible. I see the procedure in the how to docs. Any advice appreciated.
Mike
95 Pearl Blue L |
Re: Leaking coolant line
Yes, the manifold will need to be removed. There are a lot of small hoses under it that will be very hard and brittle from years of heat.
