Old 02-16-2010, 05:48 PM
blackbolt94red's Avatar
blackbolt94red blackbolt94red is offline
1st one red, 2nd one black
Post Aviation Art/B-17 and Bf109
Time on my hands here at the 'ol library, cruising my latest historic aviation catalog and came across a print titled "A Higher Call" by artist John Shaw. It was a new story to me and I found more at another forum which looks interesting. Heres the story.
ps. i'm guessing you can also see the print at www.HistoricAviation.com
here also is a great story of when these two guys finally met http://www.military.com/Content/More...le=dday_0033p1
Franz Stigler's act of chivalry
Quite incredible story IMO....
Aviation History - Charlie Brown's Story
Charlie Brown was a B-17 Flying Fortress pilot with the 379th Bomber Group at Kimbolton, England. His B-17 was called 'Ye Old Pub' and was in a terrible state, having been hit by flak and fighters. The compass was damaged and they were flying deeper over enemy territory instead of heading home to Kimbolton.
After flying over an enemy airfield, a pilot named Franz Steigler was ordered to take off and shoot down the B-17. When he got near the B-17, he could not believe his eyes. In his words, he 'had never seen a plane in such a bad state'. The tail and rear section was severely damaged, and the tail gunner wounded. The top gunner was all over the top of the fuselage. The nose was smashed and there were holes everywhere.
Despite having ammunition, Franz flew to the side of the B-17 and looked at Charlie Brown, the pilot. Brown was scared and struggling to control his damaged and blood-stained plane.
Aware that they had no idea where they were going, Franz waved at Charlie to turn 180 degrees. Franz escorted and guided the stricken plane to and slightly over the North Sea towards England. He then saluted Charlie Brown and turned away, back to Europe.
When Franz landed he told the CO that the plane had been shot down over the sea, and never told the truth to anybody. Charlie Brown and the remains of his crew told all at their briefing, but were ordered never to talk about it.
More than 40 years later, Charlie Brown wanted to find the Luftwaffe pilot who saved the crew. After years of research, Franz was found. He had never talked about the incident, not even at post-war reunions.
They met in the USA at a 379th Bomber Group reunion, together with 25 people who are alive now - all because Franz never fired his guns that day. Research shows that Charlie Brown lived in Seattle and Franz Steigler had moved to Vancouver, BC after the war. When they finally met, they discovered they had lived less than 200 miles apart for the past 50 years!!
Franz Stigler:
When enemy was a friend
Brown's B-17 was perhaps the most heavily damaged bomber to return from combat. It survived because of an enemy's act of chivalry.
Dec. 20, 1943, was a typically cold, overcast winter day in Britain as 2d Lt. Charles L. Brown's B-17F lined up for takeoff. It was 21-year-old Charlie Brown's first combat mission as an aircraft commander with the 379th Bomb Group, the target an FW-190 factory at Bremen, Germany. He and his crew of Ye Olde Pub were to become participants in an event probably unique at that time in the air war over Europe--a mission that would remain shrouded in mystery for many years.
The bombers began their 10-minute bomb run at 27,300 feet, the temperature: negative 60 degrees. Flak was heavy and accurate. Before "bombs away," Brown's B-17 took hits that shattered the Plexiglas nose, knocked out the number two engine, damaged number four--which frequently had to be throttled back to prevent overspeeding--and caused undetermined damage to the controls. Coming off target, Lieutenant Brown was unable to stay with the formation and became a straggler.
Almost immediately, the lone and limping B-17 came under a series of attacks from 12 to 15 Bf-109s and FW-190s that lasted for more than 10 minutes. The number three engine was hit and would produce only half power. Oxygen, hydraulic, and electrical systems were damaged, and the controls were only partially responsive. The bomber's 11 defensive guns were reduced by the extreme cold to only the two top turret guns and one forward-firing nose gun. The tailgunner was killed and all but one of the crew in the rear incapacitated by wounds or exposure to the frigid air. Lieutenant Brown took a bullet fragment in his right shoulder.
Charlie Brown figured the only chance of surviving this pitifully unequal battle was to go on the offensive. Each time a wave of attackers approached, he turned into them, trying to disrupt their aim with his remaining firepower. The last thing oxygen-starved Brown remembers was reversing a steep turn, becoming inverted, and looking "up" at the ground. When he regained full consciousness, the B-17 was miraculously level at less than 1,000 feet.
Still partially dazed, Lieutenant Brown began a slow climb with only one engine at full power. With three seriously injured aboard, he rejected bailing out or a crash landing. The alternative was a thin chance of reaching the UK. While nursing the battered bomber toward England, Brown looked out the right window and saw a Bf-109 flying on his wing. The pilot waved, then flew across the B-17's nose and motioned Brown to land in Germany, which the aircraft commander refused to do. After escorting them for several miles out over the North Sea, the Luftwaffe pilot saluted, rolled over, and disappeared. Why had he not shot them down? The answer did not emerge for many years.
The B-17 did make it across 250 miles of storm-tossed North Sea and landed at Seething near the English coast, home of the 448th Bomb Group, which had not yet flown its first mission. The crew was debriefed on their mission, including the strange encounter with the Bf-109. For unknown reasons, the debriefing was classified "secret" and remained so for many years. Lieutenant Brown went on to complete a combat tour, finish college, accept a regular commission, and serve in the Office of Special Investigations, with the Joint Chiefs of Staff, and in other Air Force and State Department assignments until his retirement. He now lives in Miami, Fla., where he is founder and president of an energy and environmental research center.
The image of his strange encounter with the Bf-109 remained firmly embedded in Charlie Brown's memory. In 1986, he began a search for the anonymous pilot. Finally, in 1990, former Oberleutnant Franz Stigler, now living in Canada, responded to a notice published in a newsletter for German fighter pilots. By comparing time, place, and aircraft markings, it was determined that Stigler was the chivalrous pilot who had allowed Brown's crew to live. Not surprisingly, Brown and Stigler have become close friends.
On that December day in 1943, there had been two persuasive reasons why Stigler should have shot down the B-17. First, earlier in the day, he had downed two four-engine bombers and needed only one more that day to earn a Knight's Cross. Second, his decision to not finish off the aircraft was a court-martial offense in Nazi Germany and if revealed could have led to his execution. He considered these alternatives while flying formation with the B-17, "the most heavily damaged aircraft I ever saw that was still flying." He could see the wounded aboard and thought, "I cannot kill these half-dead people. It would be like shooting at a parachute."
Franz Stigler's act of chivalry has been justly, though belatedly, honored by several military organizations here and abroad. On the other hand, Charles Brown was not decorated for his heroism over Germany, which never was reported by the 448th Bomb Group at Seething to his commanders. Such are the fortunes of war and its aftermath.
You can find interview with him and his other war stories on the following link:
http://www.virtualpilots.fi/hist/WW2...y-Stigler.html
...me again, I've got several Keith Ferris prints that I treasure (anyone seen the mural in the WWII gallery at Air and Space in DC?) but this is differnet in tone and flavor. I'm putting it on my birthday wish list.
bruce
“I distrust those people who know so well what God wants them to do, because I notice it always coincides with their own desires.”
Susan B. Anthony
"The Dildo of Karma rarely comes lubed." -- Unknown
The inventor of the doorbell did not own a dog.
Last edited by blackbolt94red; 02-16-2010 at 06:00 PM. Reason: nothing better to do
Old 02-16-2010, 06:33 PM
MadMaxSvx's Avatar
MadMaxSvx MadMaxSvx is offline
Re: Aviation Art/B-17 and Bf109
Amazing history! War can show the worst and the best of people.
I always liked the B-17, was for sure the best plane in WW2, and a tough one for sure.
Here a few images to illustrate this amazing history:
The B-17 being escorted by the BF-109
Surprized crew
Franz saluting
Franz and Charlie reenacting the encounter
They are good friends now
By the way, this plaque sinthesizes another history of bravery to save an enemy
95´ Subaru SVX EURO
85' Mercedes 190 2.3-16
86' Mercedes 190E
70' Olds Toronado
98' Renault Chamade
82' Honda Prelude
79' Honda Accord awaiting restomod.
69' Mustang Hardtop
67' Jeep Ford Willys awaiting restoration.
67' IKA Torino Coupe
74' Renault Torino Coupe
