Old 01-15-2005, 10:04 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Installed Rebuilt Front Axles...
One of my planned Winter mods/maintenance was to get two new rebuilt front axles for my car, as my driver's side cv joint made an occassional tick-tick sound at low speeds ever since the day I bought it last April.
Put my car up on the lift at Tom's (Svxfiles) place and 1.5 hours and two Coors each later, the new axles were installed!
Old Axles
Old (bottom) vs New (top) Axle
New Front Axles Installed!
Out of curiosity, I weighed an old vs rebuilt axle on Tom's digital scale and both weighed 16lbs each.
As I plan on drag racing/autoXing my car heavily this year, I had Tom look over my suspension components and everything seems to be in order. My ball joints are nice a firm!
-Chike
2006 Steel Gray WRX TR (sold)
Old 01-15-2005, 10:37 PM
n00b on demand's Avatar
Not to get off topic but are those the O2 sensors in the exhaust?
Old 01-16-2005, 06:05 AM
gsodonis's Avatar
gsodonis gsodonis is offline
YUP!
If your SVX is a OBDI car (92 - 95), you have two sensors (they are both the same) just like you see in the photo.
If you have a OBDII SVX (96 - 97), you have a third O2 sensor (this one is different from the front two) attached to the main CAT.
Old 01-16-2005, 10:47 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Chike,
Good stuff! Did an "up close" inspection of the old axles show any specific wear?
Looks like you've had one of your primary O2 sensors replaced somewhere along the line, as the insulation is different on the two in the picture.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 01-16-2005, 11:41 AM
92black svx
i see that u took ur axles out by taking the splinny thing out of the axles what happens if u just pull them from the trans
Old 01-16-2005, 11:56 AM
Chiketkd's Avatar
Originally posted by SVXRide
Chike,
-Bill
Bill,
I looked over the used axles and found no visible signs of wear. Tom mentioned that this was the quickest axle swap he'd done and everything popped out very easily.
The insulation is the same, but one 'sheath' seems not to want to stay over the lower part of the wires for some reason...
-Chike
Old 01-16-2005, 12:00 PM
Chiketkd's Avatar
Not sure I understand your question, but Tom and I removed the axles by popping out the little metal clip that locks them in place (near to the front diff), and then undoing the bolt that locks them into the wheel hubs. From there, we removed the one bolt on each side that connects the lower control arm to the hub (by the ball joint). In doing this, we were able to swing the hubs outward, and slowly wiggle the axles out.
Everything went smoothly.
-Chike
Old 01-16-2005, 12:03 PM
92black svx
ok thanks i saw a tran i was going to get at a junkyard just incase mine evr fails but the axles where pulled from the trans just making sure that it will still be okay
Old 01-16-2005, 12:08 PM
Chiketkd's Avatar
My trans and front diff are from a '96 Impreza Outback Sport. The SVX axles (old ones and the rebuilt) popped in like a charm.
-Chike
