exhaust question
okay I know that the exhaust system is already very well designed and it would be hard to improve upon but I was wondering what would happen (besides the fact that you would fail emissions test) if you took off all of the three cats and then made a completely separate "true" dual exhaust setup with two resonators & mufflers, let's say out of 2" piping would you lose the scavenge effect of the stock system, any possible gains from such a conversion???? thanks for any response
rumor has it
That there's not much resistance caused by the cats anyway. So, if you did take them all out, I'm not sure what you've gained. As far as the true dual setup, I think that may be something worth doing. From what I've hear, there is noticeable performance gained from that. You can ask 1994SubaruSVX for his input because he has a true dual setup. I'm aboot to mess with the cats cuz they're buzzing like mad. Midas said they're falling apart but that I don't need to worry about it because they aren't creating any backpressure. I'm not sure what I think about that diagnosis. So, that's my 2 cents.
Mat
Time for my very own long list of mods: 92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ) - BMW E46 HID retrofit - Kenwood Headunit - Phoenix Gold 75x4 RMS amp - Alpine Type R 6.5" front components - Alpine Type R 6x9 3way rear speakers - 18"x9" Rota G-Force wheels w/225/40ZR18 Toyo T1R's - Mychailo's custom springs - Urethane front & rear sway bar bushings - KC exhaust (2.5" dual magnaflow) - Escaine seat swap - Removed Spoiler I don't care if Subaru says it's STI...it will always be STi to me |
PM me .......
i will tell you all you need to know.
1994 SVX, true dual Magnaflow exhaust, K&N filter, 17" Enkei RS6 wheels, Bridgestone Potenza RE730 225/45/17 rubber, zinc plated cross-drilled rotors with yellow painted brake calipers. B&M tranny cooler rated at 19,000 GVW. GC springs and Koni strut inserts installed and the car is lowered two inches all the way around!! "Too much fun to drive!" |
Re: exhaust question
As far as a balance or crossover pipe is concerned, this is used to quieten the exhaust sound from the rear of the car. If you were standing at the back of the car with dual exhaust pipes, the sound would come from one pipe then the other pipe as pressure pulses. Put a pipe between the duals and now, from the back of the car, the sound pulse comes half from both pipes, to quieten the sound level. This pipe is not needed unless sound is too excessive. It should not be placed between the pipes, close to the header pipes as it will allow pressure from one bank of cylinders to affect the other side. I don't think there would be an increase in power from the system, But it certainty would sound different, more of a BLAT,,,.BLAT sound. The problem would be in trying to fit it under the car. Anyway thats the way I see it mate. Harvey.
cool, that pretty much answered all of my questions, thanks for the replies...
