Old 02-07-2011, 05:25 PM
92 SVX 92 SVX is offline
Had a very busy weekend
Been busy this weekend friday I had to get a new tire, discount tire store had what I needed. Sat I set about to change my rotors and pads and put SS brake lines on. I found one front lug nut had been cross threaded and it broke off. My rear tire had another cross threaded nut but it did not break off it wore a groove into the stud and was just spinning. I put tires back on went back there to have them get it off, the shop they use for that was closed on the weekends I ended up getting it off by applying pressure to the back of the tire and pushing it off while using an impact on the nut.
So got the tires off the car finally but 2 studs destroyed, I then changed out the lines and pulled the rotors pounded out the studs and went to the parts store and got new ones front was very easy got it in new rotor on and new ceramic pads on. Moved on to the rear, that dang drum type parking brake sucks took a bit of time but got that one done as well the rest of the lines rotors and pads went fairly smooth.
Sunday went to ocala fl with my new drop springs and got some struts and mounts he helped me put them in he has air tools so that helped a lot. Not sure if he is a member here but he is on the world forums, silver92mike if you see this a very very big thank you. got a few other parts from him as well, the rear deck cover looks amazing carpet is not peeling. Today my 97 grill finally came in about 5pm at the moment its just grey I will get it painted white or possibly black soon.
Today had lots of things to do so I couldnt get pictures in better light beside it rained all day so there was never great light.
Here are a few pictures of the results.
This isnt a very good picture of me, though dont think there are any good ones
The body shop came through very nicely on my stereo
the pic onscreen is my youngest son.
This one gets info from the radio station on song and artist.
These are the struts I pulled out of the car, will reuse them for the koni's soon as I can get them. 3 never came back up since sunday when we pulled them
Old 02-07-2011, 05:26 PM
Re: Had a very busy weekend
It would only allow 10 pictures per post so here are the rest.
I compressed the 4th one and had time to pick up the camera and take a pic
A second pic about 45 seconds later
And the mounts, the front are collapsed but the rear dont look too bad though I am unsure of what exactly they should look like.
Old 02-07-2011, 05:54 PM
I can't believe I almost forgot about the Ecutune stage 1 and tcu I put in sat night. Really makes a nice change.
Old 02-07-2011, 06:23 PM
Looking very good!!
Old 02-09-2011, 01:48 PM
Ok got around to taking some good sunny daylight pictures.
Old 02-09-2011, 04:58 PM
Banned
looks good!
Old 02-09-2011, 05:07 PM
Looks good.
Any chance you can measure and weigh the struts? Would be helpful to me to figure out shipping on mine if I ever get them off.
Old 02-09-2011, 05:37 PM
Looks good.
I can, though the weight will only be with a bathroom scale, dont have anything more precise.
Old 02-09-2011, 06:00 PM
I see you went with the white grille, good choice!
Old 02-09-2011, 06:01 PM
Actually at the moment it is grey, have not had a chance to get it painted yet.
It only came monday after 5pm.
Old 02-09-2011, 06:03 PM
Oops, in the sunny shots it looked white. Well at least you know my vote on that one.
Old 02-09-2011, 07:07 PM
That's great, I just need a ballpark.
Old 02-10-2011, 05:18 AM
Andrew P.'s Avatar
Andrew P. Andrew P. is offline
The Ebony ones are faster.
Very nice.
How did you tint the tail light panel?
Also, what did you use for the carbon fiber dash?
92' Ebony. Magnaflow exhaust, tinted windows, STI wheels, 97' grille, Bontrager Works SB, ECUtune transaxle and TCU.
77' IHC Scout SSII
Old 02-10-2011, 10:20 AM
Originally Posted by Andrew P. View Post
Very nice.
I used VHT Nightshades spray tint
And the Carbon fiber dash was from bonestock here
http://www.subaru-svx.net/forum/show...3&postcount=20
Old 02-10-2011, 12:21 PM
Looks good.
OK rear struts uncompressed lenght is just under 25" weighs about 10.8 pounds
the Fronts are 22.25" and weighs about 9.8 or 10 pounds. I wasnt able to get a exact number on that one.
