Old 11-05-2015, 07:05 PM
lsupcar lsupcar is offline
WTB Transmission mount
Looking for a very good transmission mount for a 1992 L-SL.
Thanks.
Bill Z
Old 11-13-2015, 04:31 PM
Re: WTB Transmission mount
Bump
Any of you dismantling cars have a tranny mount in decent shape?
Thanks.
Old 11-15-2015, 03:11 PM
fasteract7's Avatar
fasteract7 fasteract7 is offline
A new 98 Legacy auto mount will work with the one stud cut/ground off...pretty cheap on eBay/RockAuto.
Old 11-15-2015, 04:44 PM
Is that true? It will work just as well?
That is great info.
Thank you so much.
Bill Z
Old 11-15-2015, 05:53 PM
fasteract7's Avatar
If you have access to a grinder, just get one for a 98 legacy outback. They are the same, except the Legacy mount has one additional stud over the SVX.
Old 11-16-2015, 06:13 PM
There are more '98 Legacy models and variants then I was expecting.
Just to be sure is the part number 41022AE121 ?
That is for a '98 legacy 2.5L AT 4WD.
The picture looks a little different then the SVX.
Just want to make sure it will fit.
Thanks.
Bill Z
Old 11-17-2015, 12:23 AM
fasteract7's Avatar
From RockAuto..1998 Legacy..the mount is the same for the 2.2 and 2.5 liter motors..look under "Transmission, auto", then "Mount". I have emailed my source for this SVX/Legacy swap info to confirm and will follow up as soon as he gets back to me.
WESTAR EM9074 Info
Automatic trans. (Only 6 Remaining)
Part Image
$20.79
Add Part
DEA A6714 Info
Automatic trans; Confirm original mount has 4 studs (Only 3 Remaining)
Part Image
$30.79
Add Part
ANCHOR 9074 Info
Part Image
Choose:
$35.79
Add Part
BECK/ARNLEY 1041528 Info
Part Image
$44.79
Old 11-30-2015, 03:27 PM
Jvan Jvan is offline
Are we talking about the rear AWD transmission mount. I recently had the transmission in my 95 rebuilt and it failed last week (still under warranty). The mechanic called today and said that the rear transmission mount had failed, allowing the transmission to wiggle and trans fluid to leak out. He said he couldn't find a replacement since the part has been "discontinued" and is listed as "obsolete". How could a required part be "obsolete"? I hope we are talking about the same part since I don't want to get rid of the car for a minor but essential part.
Old 12-01-2015, 07:51 AM
Yes, the part I was looking for was a rear transmission mount for a 1992 LS-L, which is AWD
Old 12-01-2015, 07:55 AM
fasteract7's Avatar
There is only one transmission mount for the AWD on top of the trans subframe cradle unless you count the "dogbone" up top. The dogbone is still available while the 98 Legacy will do for the other with the one stud removal mentioned previously.
SUBARU Genuine Factory Part
Fits 1992 SUBARU SVX LSL
Part Number: 41040FA000
Damper strut (Dogbone)
Item #7 on image
MSRP
$65.02 Online Price
$54.61
Old 12-01-2015, 08:05 AM
Is the transmission mount 1 or 2 pieces? RalliTEK sells a insert using the OEM mount but it's only for the 1 piece mount. As for the 98 Legacy part, which stud is removed since there are 4 studs on the SVX mount and 4 studs on the Legacy mount but I assume one of the studs is in the wrong place?
Old 02-01-2016, 07:09 PM
As a follow up.
My shop installed the above referenced Legacy mount and said it installed perfectly and no studs had to be ground off.
Old 02-02-2016, 04:12 AM
fasteract7's Avatar
Great...could you tell us what exact year Legacy, model and part # ???
Thanks
Old 02-02-2016, 08:57 AM
slowner44's Avatar
slowner44 slowner44 is offline
I just replaced the rear AWD mount on my car over the weekend.
I used this one:
http://www.ebay.com/itm/Transmission...-/261877403794
And I did have to cut off the stud that didn't form a straight diagonal line like the others do.
Old 02-02-2016, 08:20 PM
The Subaru part I used was the one I referenced above for a '98 AWD Legacy.
part number 41022AE121.
Hope this helps.
