Jdm cam vs usdm cams.
Hey guys. I got a 92 lsl with jdm engine swap and usdm harness and ecu...anyway. I need to replace my passenger Exaust cam and called Subaru dealership and they said the jdm cams were different that usdm. Any truth to this or will a usdm cam work as a replacement.
Re: Jdm cam vs usdm cams.
I would think that the cams may be different, as you don't have 96 - 98 octane available in most of USA.
or if the cams are the same then the pistons may be different - to give compression variation?. anyway that is my thought.... If you use JDM ones you might need to add fuel additive to stop pinking..
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
We have what you call 96-98 octane, but not named as such.
Stolen from a thread I came across in a reddit post: Quote:
Japans petrol is highly refined, much better than any UK fuel, I was in Tokyo about 4 years ago, and remember seeing 103-105 on the pumps. I also owned a Subaru Impreza WRX STI V5 several years ago, it was a JDM (grey import) It would pink on UK 98 petrol, it was essential to add octane booster, or risk engine failure. Many owners of Jap import cars learned the hard way, octane booster and remap is the way to go.
I do not see why you all are talking about octane level of the fuel. I follow what you are saying but do not understand why. What does that have to do with the cam? If the octane value is different in another country, I would think a remap of the ecu should be sufficient in managing the engine timing and the amount of gas injected. Why change the cam for such a small amount of difference? I am sure you will have a good answer for me that I am not aware of.
[SIGPIC][/SIGPIC]Kenyatta The farther backward you can look, the farther forward you are likely to see. -Winston Churchill My baby: 94 lsi ![]() My fast baby: 2001 Suzuki Marauder ![]() My new baby: 2010 Subaru Outback ![]() |
