Old 07-08-2003, 10:02 AM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
Idle adjustment?
Is there an idle adjustment or do you just get whatever the computer gives you? Ever since my 5 spd swap, my idle has been sitting at 600 rpms. I would like to bump it up a little.
Stephen
92 Ebony - Level 10/n2o REAR-ENDED
92 Teal - painted yellow/4.11 5spd/n2o SOLD
92 Claret - 4.44 SOLD
94 Barcelona - FWD SOLD
92 Ebony - 3.90 SOLD
94 Laguna ROLLING w/4.44s/Ecutune ECU +TCU/STI springs/Infiniti M45 rims
Old 07-08-2003, 11:13 AM
mbtoloczko's Avatar
sans SVX
Re: Idle adjustment?
Stephen
There is a set screw to adjust the closed position of the butterfly, but everyone says not to mess with it. Maybe there is a way to convince the ECU that the car is in drive so that it will bump up the idle a bit? Maybe that would bump it up too much?
Mychailo
Visit my locker
Old 07-08-2003, 11:25 AM
I would check with Lwin first. He did some adjusting on that and would know what to do or not to do.
Old 07-08-2003, 12:24 PM
Phast SVX's Avatar
Phast SVX Phast SVX is offline
BOOOOOOOOOOOOOOOOOST
Send a message via AIM to Phast SVX
we also need to figure out how to make the car think it is in drive so that fuel cut does not come on at 6500 rmp. The car should rev to 7, but it thinks its in nuetral and seems to have a neurtal fuel cut off so you dont blow your engine I think it would require a toggle switch to be turned off for startup and then on once you get the car oon flip it over. I dont have the wiring know how or meterial, stehpen do you have the wiring diagrams??
phil
PS why would putting the car in drive change the idle? There is no BISS screw as far as i have found, but the throttle position sensor can be turned to adjust the idle, mine was sitting really high after the swap and still is. It is intermittent though, sometimes its around 800 sometimes 1350. Dosnt even make a difference if the air condition is on or off my car acts different everytime i start the car idle wise. Oh well, just another one of those things you get wit ha 180k car
phil
~Phil
Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog.
Old 07-08-2003, 01:54 PM
Mr. Pockets's Avatar
Moderator
Stephen
The car is supposed to idle at about 600. Why would you want to change it? Are you stalling the car a lot at stoplights?
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 07-08-2003, 02:07 PM
elninoalex's Avatar
Registered Abuser
Yes, I have a few times. 600 seems a little low for a 5spd. My other one idled at 750-800 as did this one before the swap.
Stephen
Old 07-08-2003, 02:44 PM
mbtoloczko's Avatar
sans SVX
phil
PS why would putting the car in drive change the idle?...
phil
I don't think its a fuel cutoff that kicks in at 6500 rpm. That would be bad for the motor. I think the ecu selectively begins not firing certain cylinders. My car does this even in drive.
I think the ecu bumps the throttle position slightly when the car is put into drive to counter act the drag put on the motor by the TC.
Mychailo
Visit my locker
Old 07-08-2003, 03:32 PM
Phast SVX's Avatar
well the car literally dies after 6500 rpm, like its like you just hit a brick wall. Any ideas?
phil
~Phil
Old 07-08-2003, 05:06 PM
elninoalex's Avatar
Registered Abuser
phil
phil
I don't know if I have the necessary wiring diagrams or not. I will have to check when I get home. And the engine just seems to stop suddenly at 6500 rpm.
Stephen
Old 07-08-2003, 05:49 PM
mbtoloczko's Avatar
sans SVX
phil
Hmmm. That's different behavior than my car. Even with the selective "misfiring", I've seen my motor pull all the way to 7200 rpm before the AT shifts. Maybe there is something going on with the car thinking its not in drive with the 5MTs. Does cruise control work on your car?
Mychailo
Visit my locker
Old 07-08-2003, 08:56 PM
SubaSteevo's Avatar
No longer blue member
If I remember
I read somewhere that in "normal mode" the car will only go to about 6000rpm (don't remember the specificis) but if in power mode it will go all the way to redline. Then again that is with the AT so if you did a 5spd swap it might always be limited. If you haven't already, try disconnecting the resistor so that the car always "thinks" its in power mode. Might or might not do anything, sorry, I don't know much about transmissions besides the fact that they are expensive to rebuild. Normal idle range is between 600-800 (I think).
-Steve
01' MSM Lexus IS300
Old 07-08-2003, 10:18 PM
elninoalex's Avatar
Registered Abuser
I don't know, I have never used it before or after the swap.
Old 07-08-2003, 10:58 PM
mbtoloczko's Avatar
sans SVX
Let me know if you try to use it.
Mychailo
Visit my locker
Old 07-09-2003, 06:23 AM
Phast SVX's Avatar
we need to find someone with the wiring diagrams, i for one would really like to have my entire power band back, the car should have power all the way to 6800 rpm, so if anyone has the proper wiring diagrams please let us know!
phil
~Phil
Old 07-09-2003, 06:26 AM
Phast SVX's Avatar
Re: If I remember
i cant see this helping, becuase we completely removed the the TCU to fit the clutch pedel assy in. Maybe we need to reconnect the tcu...grrrr welll time to play around. ill see if i can get it hooked in and up there
phil
~Phil
