Not shifting out of park?
lately i have been having a problem with my car not wanting to shift out of park after i turn it on. i depress the button on the shifter and it will not budge. it will eventually shift after the car has been on for a minute or so and then it will shift out of park. and is fine from then on.
anybody know whats up with my car??? |
Well first the obvious question, Are you depressing the brake when trying to shift out of park?
Do you hear the lock release when you depress the shifter button? Is it hard to move the shifter thru other gears (R-N-D-3-2-1)? Prior to the car warming up "enough" to shift, have you tried the lock release on the base of the shifter?
1992 Liquid Silver LS-L (Sold-5/16/13) 1997 Spruce Pearl Outback (Sold) 2006 B9 Tribeca |
1)brake will be depressed completely. 2) definately hear the lock release noise comming from over by the steering collumn 3) moves through the gears fine after i get it out of park. 4) i have never messed with the lock release. tell me what i need to know about it. |
The lock release is a small slide "switch" on the upper left corner of the shift indicator console (iirc) It allows you to release the shift lever in the event of the brake release malfunctioning.
If your hearing the lock release when your steping on the brake and pushing in the shift button, I can't really say for sure what the problem is, I would guess that the lock release is sticking for some reason, and frees up when the car warms up. If I can find the time (short handed at work) I'll take a pic of it for ya. (or if someone else get's to it first/has one already please post it)
