Reading ATF dipstick
Sorry for the dumb question, but I don't have an owner's manual and I'm having trouble reading my ATF dipstick. It has three holes or marks about the same distance apart (1/2" or so) from bottom up. Can someone explain the marks to me? How much fluid needs to be added to go from one mark to the next one up? Is the top mark "full" or is it "you added too much, dummy." I've always had a little trouble reading ATF dipsticks because ATF doesn't seem to stick to it the way oil does to an oil dipstick. Any help is appreciated.
This is very simple to explain:
The dipstick has 2 sides, a COLD and a HOT side. These are marked on the very bottom of the dipstick. If you are checking the ATF when the engine is cold and the car hasn't been driven to warm it up, use the COLD side of the dipstick to measure. The first hole from the bottom is the low mark and the middle hole is the upper level (full) mark. Fluid should be somewhere in between, but closer to the full mark. If the car is at normal operating temperature when you check the ATF, use the HOT side of the dipstick. On this scale, the middle hole is the lower fluid level and the top hole is the upper level (full). Again fluid should be in this range, closer to the full mark. Do not overfill. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 10-02-2005 at 05:59 PM. |
