Probe dyno video - 540whp 427'lb torque
Love this video, was a guy on a board i was a member of a while ago. He had eagle rods, ross pistons/rings, running 20lbs of boost if i recall correctly on a t3/60-1, completely street legal.
http://simplepic.net/displayimage.php?album=7&pos=6 I know you folks aren't a fan of the probes most likely, but i had a few and used to do some "fun" stuff with them. It's a really great platform to learn on, and while you can't make giant power without tons of $$$, you can make healthy power for not much, learn a lot, and go pretty quick, as the car doesn't weigh much at all.
*No SVX at the moment...* 1987 Winnebago Elandan 35' 2001 Yamaha Roadstar 1600 2004 Ford Excursion Eddie Bauer, 6.0litre Power Stroke Diesel - Daily Driver. Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, scotch in one hand, body thoroughly used up, totally worn out and screaming HOOOOYA !!!!! Last edited by JaySVX; 08-31-2007 at 05:33 AM. |
If I recall correctly, he was only running 18 psi on that run and that motor was not his built motor. This is an otherwise stock DE engine aside from the standalone and turbo stuff. He has spent countless hours on the dyno though, and has tuned the car very well.
That's what I remember reading over on probetalk anyways. It's pgtracer right? Victor? I've seen that video a dozen times before now, and I'm fairly certain this was on a stock motor. p.s. if you got this from probetalk, my handle is nevin94 PGT. Cheers!
Jesus is the remedy 2015 Expedition EL Ecoboost Ebony Pearl '95 Subaru SVX LSi Home of the Bontrager Works 22mm rear sway bar!! |
