engine oil cooler?
Hi everyone, I want to know if is no problem to run an oil cooler(sti s203) with my stock oil pump.
Not too much hose, using a *sandwhich with thermostat thanks |
Re: engine oil cooler?
Works absolutely fine. You only need a couple of tee pieces to make it work with the stock water line setup. You also need to replace the block bolt with a water one so the block can feed the oil cooler.
Is that the same bolt a block heater goes into?
water line? The sti oil cooler is not a water/oil cooler, its a air/oil so I just have to use the oil filter adapter and the oil cooler example: http://www.google.ca/imgres?um=1&hl=...r:5,s:27,i:173 thank |
can be a good cooler? or it can do pump cavitation at high rpm? or it not gonna do a big change on the oil pressure or the oem subaru water/oil would be better? Last edited by shark_22; 07-17-2012 at 12:25 PM. |
The water that feeds it comes out of the block and is post thermostat water - so it keeps the oil cool on hot days and warm on cold days. |
