Old 01-20-2006, 01:26 AM
svxsubaru1's Avatar
svxsubaru1 svxsubaru1 is offline
SpeedTV Petition; more F1 & WRC
http://forums.nasioc.com/forums/showthread.php?t=923794
92 Honda CBR 600
95 Miata
Old 01-20-2006, 06:57 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Signed!
-Chike
2006 Steel Gray WRX TR (sold)
Old 01-20-2006, 09:54 AM
Earthworm's Avatar
Meow!
I'd be happy if Nascar was completely eliminated (or at least oval tracks in general).
Old 01-20-2006, 12:58 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Hmmm... Now there's a waste of time. Their first push was when Speedvison was bought but they didn't feel ready to go 100% against real racing at the time. It was bound to happen sooner or later.
Old 01-20-2006, 01:04 PM
n00b on demand's Avatar
They really need to cut the nascar crap out. Its boring and not very good to watch. More WRC would definitley make me tune in more. Last time they had a WRC program i even taped it since i love that stuff.
Old 01-20-2006, 01:57 PM
Chiketkd's Avatar
The thing about all of the NASCAR on SpeedTV is that most isn't actual racing, but those annoying 'post race analysis' shows where everyone is just yelling back-n-forth at each other. Even if I was into NASCAR, those shows would turn me away...
Old 01-20-2006, 01:58 PM
benebob's Avatar
You guys do realize that it is owned by Nascar right? (well Fox and Nascar)
Old 01-20-2006, 02:17 PM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
Signed. Also asked for V8 Supercars, DTM, BTCC, more FIAGT and LeMans Endurance Series. Don't mind the tuner shows. You're right about the post race analysis and talk shows. Listening to a Nascar driver talk about racing is almost as interesting as listening to an NBA player talk about basketball. The level of eloquence is similar, only the accent is different.
