Old 06-24-2009, 04:56 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Fixing lifters on 2.0 Mazda 626
Well my moms 1997 Mazda 626 crapped out yesterday. She ran it dry and put in used oil. Well I tried starting it and the lifters tick very bad but go away when you rev it. It blows a lot of blue smoke out of the exhaust (has worn rings). She also said that the temp gauge rose up and she put the heat on full blast to help it a little. Is this worth fixing the lifters/other attached componants or should it go to car hell. Also if it seems fixable how would I go about removing the lifters and getting torque specs for them. thanks
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 06-24-2009, 05:23 PM
siceclipse's Avatar
siceclipse siceclipse is offline
Re: Fixing lifters on 2.0 Mazda 626
raising temp?
did the head gasket go?
Lifters are really easy and you can do them in an inline 4 in about an hour or two.
Mike
1992 SVX LS-L Pearl White 102,000 miles (Gone)
2005 Evolution 8 SSL Tarmac Black (new daily)
1995 Eclipse GSX Durango Copper Pearl (teh beast)
276awhp/280awtq @ 18psi (560's inj)
260awhp/260awtq @ 17psi (stock inj)
Old 06-24-2009, 05:35 PM
Well I just torn in the motor and the lifters don't looked scoured. I did find that both the accessory belts were toast which is why I think the temp rose because the water pump wasn't going. I'm going th advance auto to get some new belts and a can of seafoam and see what happens from there.
Seth
Past subies:
Other toys:
Old 06-24-2009, 07:55 PM
y2daniel1981's Avatar
y2daniel1981 y2daniel1981 is offline
if you need any more help, check out the guys at performanceprobe.com. It's a very knowledgable place and your 626 uses the same engine as the probe of that year
Old 06-24-2009, 08:08 PM
Thanks. It turns out the valves maybe bad. I got the new belts on and ran 1/2 a can of seafoam in it for about 5 min. I'm going to change the oil tomorrow and add the rest of the seafoam in it and see what happens.
Edit: I looked at that site and cannot find anything related to my problem
Seth
Past subies:
Other toys:
Old 06-24-2009, 08:47 PM
NiftySVX NiftySVX is offline
The lifters pound the plungers internally and are destroyed if they loose oil. I would be willing to bet the car is not worth fixing, because it probably needs at least valve seals, and depending on how low on oil, bearings, or a block. You know it burns oil so it probably needs some major engine work.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 06-25-2009, 11:47 AM
Today I took it to my girlfriends pap who is a mechanic to look at it. After hearing it and seeing the cloudy trail of smoke behind me we came to the conclusion that some of the valves are shot, possibly more than 1 broken piston ring. So the motors junk and the car may go to the junkyard even with a good 5 speed in it.
Seth
Past subies:
Other toys:
Old 06-25-2009, 11:54 AM
Mike621 Mike621 is online now
That generation of 626 is fairly problematic anyway...
Time to find her a Legacy!
Old 06-25-2009, 11:57 AM
There was actually a 92' Ebony SVX down the road with a blown tranny I wanted her to get but I think the person who owned it took it to the junkyard.
Seth
Past subies:
Other toys:
Old 06-25-2009, 12:27 PM
subeman90's Avatar
Soobologist
put another engine in the 626? there has to be one somewhere in a JY.
15 OBW premium w/eyesight
Old 06-25-2009, 12:39 PM
I know where one is, but it's going to cost near $1000 for the motor+labor.
Seth
Past subies:
Other toys:
Old 06-25-2009, 07:00 PM
Well you'll have to actually get inside the forum and look around. Look for the 2.0 engine from the SE
Old 06-25-2009, 07:10 PM
I did, I looked through every possible page.
Seth
Past subies:
Other toys:
