Old 10-28-2006, 05:23 PM
It's Just Eric's Avatar
Missing in action
Strange electrical problem
Right now i'm battling an elusive electrical gremlin. The symtoms are pretty easy to describe...When I turn the key to start the car, nothing happens. the starter doesnt turn at all, not even a click. Theres no electrical sounding noises at all. The lights go dim when I turn they key, but thats about the only indication that anything is happening.the battery has a full charge. My guess is that power is either somehow not getting to the starter, or possibly I have a bad ignition.
my guess as of right now is the ignition. All the wires to the starter are securely bolted into place, and all the grounds connected.also, the key seems to fit rather loosely in the ignition. Actually, I have a key to my other svx on my keychain that happens to be a similar cut as mine, so for laughs I tried it. It not only went all the way in, but also turned to start (with the same failed results as with the correct key)
Any suggestions? Im not exactly an electrical genious, so any guidance is appreciated. Is the ignition a likely cause? Where else should I start in diagnosing the problem?
Thanks in advance,
-Eric
R.I.P Cool Signature.
Old 10-28-2006, 06:04 PM
SVXtacy SVXtacy is offline
It's called the Starter Solinoid. Biggest ***** to ever figure out for the life of me.
Old 10-28-2006, 08:13 PM
Eric, pop the steering column plastic off and check to be sure the ignition switch is mounted tightly against the ignition cylinder... I had mine pop off in the teal and she would no start... took me forever to figure it out I even changed the starter out...
Old 10-28-2006, 08:26 PM
Missing in action
calling now....
Old 10-28-2006, 11:42 PM
Trevor's Avatar
Trevor Trevor is offline
Thanks in advance,
-Eric
Specifically you state the lights go dim, I gather when you turn the key to the start position, which means that there is a connection being made and substantial current is being passed. The important criteria being that you are certain there is no associated sound and you are sure that the battery is sound.
If the dimming of the lights is what you normally experience and there is not the normal sound of the solenoid engaging, this could indicate a mechanically seized solenoid but the solenoid would have to be closed for the starter to draw the sort of current normally required to dim the lights.
The alternative is a partial short circuit bypassing current and preventing the solenoid closing and also dimming the lights. This could involve shorted turns within the solenoid, but an unlikely fault.
However the more likely and simpler explanation is a faulty battery connections or battery, contrary to what you report.
Simple logical electrical testing with a test light will locate the problem. If you wish to proceed with what is involved after further consideration, shout.
Trevor, New Zealand.
Old 10-29-2006, 11:09 PM
Trevor's Avatar
Please read again and understand what I have detailed. Meantime I apear to have waisted my time.
N.B. Quote ---- However the more likely and simpler explanation is a faulty battery connections or battery, contrary to what you report.----
Old 10-30-2006, 01:33 AM
Dessertrunner's Avatar
I have a the same problem except that mine is more of a issue when the car is hot. I have pulled the starter apart and got a slight improvement but nothing that lasted. I have check the battery terminals to no advantage. My ignition is stuffed as well. I can hear the solinade attemp to click in but the lights dim and it fails to connect. I have measured the voltage and when it fails to start the the voltage has dropped below 10. Then it comes back up when you stop trying to start. I don't know if it is of help but my car developed the problem after doing 2,000 on hard dirt road that near shock the fillings out of my teeth. I am going to look at what Tom suggested as it sound logical. I just keep clicking the Key and it finally starts.
Tony
Old 10-31-2006, 01:12 AM
I plugged voltage meter into the cigarette lighter and have been watching the voltage closly. Today it only played up once and not for long enough to get a handle on what the voltage is doing. I will come back to you after I sewe how it goes tomorrow on a 900 k trip
Old 11-07-2006, 10:13 PM
Trevor's Avatar
N.B. Refer the second paragraph.
Old 11-08-2006, 12:11 AM
Eric the starter problem is just a result of the mains relay planning up eg the voltage goes down current goes up so hit with Hammer then adds extra free force which results in getting connection.
Trevor I read some other comment you made on a different tread and agreed the problem needs to be fixed by finding the true problem.
My car is perfect since I changed the main relay under the dash.
The problem is lights go down not because to much load they go down because the connection in the mains relay won't let the full load current throught then voltage drops which then means more current till the circut is broken. Exactly as happens with a dirty battery terminal, powers good till load comes on then nothing.
Eric change the relay don't bother changing the starter done that and it doesn't get rid of the problem just may reduce its occurance.
Tony
Old 11-08-2006, 02:58 AM
Trevor's Avatar
Tony
Thanks Tony,
What you say makes a lot of sense. The main relay performs rather an arduous duty and the contacts could very well become eroded and the overtravel reduced to nil. It could probably be given an extra life with some attention, but replacing it was a wise option.
It would be worthwhile if you could open up your old one and advise what you find has deteriorated. The more practical stuff reported here the better.
Cheers, Trevor.
Old 11-08-2006, 04:10 AM
Trevor did that and it has a set of contacts that are Normally Closed and the surface is corroded. You have to destroy to open but its easy to see were it can go wrong I will try to take a photo tomorrow for you. We need to see if we can get the part number for every one. I will call my dealer tomorrow and let people know. It amazing the car gave me such grief for the last 2 months and now it never miss a beat on starting.
Tony
Old 10-29-2006, 04:53 PM
Missing in action
New symptoms:
Theres a batterey idiot light that is on when the keys arent in the ignition
Otherwise, nothing's changed. I went to the lot I had it parked overnight at,put the key in and fired it right up. Strange for a problem to simply go away without anything changing. So I drove it all day today, making stops here and there, even managed to fix my power steering pump and take it on a much deserved backroads cruise. I had to stop at my friend's houseto drop off some tools and bam, it refuses to start again. I fiddled with the ignition switch, and it does seem loose, but the screw for it is inaccesable. Pushing it in with my fingers while trying to start it has no effect. For ****s and giggles I pulled engine codes and came up with like...4 things...which is strange because everything is and sincemy engine swap, has been in good working order. Could there be a ground that is common to multiple sensor wires that has gone bonkers? could my ignition still be screwed up? Is there a relay in the main fuse box that could be malfunctioning?
Id like to figure out what the hell is wrong with this car, rather than add it to the list of fwd barcelona red L models with electrical problems being parted out (Seems likeaminor trend theese days)
Old 10-29-2006, 07:17 PM
Eric, check the ground on the back of the pass side of the intake manifold... This usually send tons of **** arie
Old 10-29-2006, 08:35 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Send a message via AIM to Budfreak
New symptoms:
When this happened to me it turned out to be a corroded positive terminal on the battery. Sometimes it was fine, and other times it would not start and the lights go dim. I cleaned the terminal and it would happen again like 3 or 4 more months later. The last time I cleaned it I sprayed on terminal protector spray and it's been all good ever since. Make sure the wires on the starter and battery are clean and tight, and check all your ground wires too for corrosion or rust.
