Old 08-07-2009, 08:48 AM
Maxo's Avatar
Maxo Maxo is offline
ABS hydraulic Unit?
I'm getting an ABS code 2 (Broken or shorted solenoid valve circuit(s) in hydraulic unit - Right Front).
I was getting this code and a hot brake smell every day until I replaced my front calipers. That was over a month ago and now it's back along with a pull to the right under normal driving and braking.
Do I have to replace the entire hydraulic unit or is there some fix for this issue? Would a line flush help any?
I'd like to get it fixed asap but don't want to buy something if there's a cheaper solution (I've already spent far too much on this car).
Old 08-07-2009, 09:55 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: ABS hydraulic Unit?
It most likely is shot, but you can try a brake flush anyways, if anything just for the fact that replacing and removing all the air out of the ABS unit is a royal PITA.
Old 08-07-2009, 05:57 PM
StelthSvx's Avatar
StelthSvx StelthSvx is offline
there are two bleeder valves on top of abs unit, what else would you have to bleed, why is it pita???? ( i need to do this haven't yet)
92' Claret LSL 282,000 miles 1owner(ME)
07' Pearly WRX 40k Cobb Stage II (sold)
SVX+$$$+GreaseMonkey =
Old 08-07-2009, 06:57 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
I have done a few.... any time you work on anything besides the calipers/wheel cylinders, such as an ABS unit or a master cylinder, you have to bleed EVERYTHING, since you have introduced air into the entire system. The air has to be bled from the replaced part, and every point downstream of the repair. The tinyest bit of air bubbles inside an ABS unit will cause a complete clusterbleep of brake troubles.
