Old 01-23-2005, 09:17 PM
clarkerussell
I'm screwed... Need advice ASAP!!!
I've just driven my SVX to orlando for a week of vacation. About half way there I noticed a loud noise from my rear wheels. I had no choice but to continue on for the rest of the 300 miles. Needless to say, the bearings are shot.. REALLY, REALLY shot.. Almost to the point of not being able to talk over the noise.
I'm leaving on Thursday so I need to take the car to a Stealer for repair ASAP. How much should it run me for a new left rear wheel bearing? Since I'm not at my house (and on vacation) I'm going to have to pay them to put it on for me and I'm really worried about getting screwed. I'm between a rock and a hard place here.
Regardless, I need to get a few questions answered:
1) In Orlando it looks like there are 3 Subaru dealers. Does anyone have a recommendation for me?
2) On Subaruparts.com when I try to add the rear wheel bearing it automatically adds two of them to the cart. I'm assuming that's two per vehicle, not per side, right?
3) At Subaruparts.com they are offering the inner and outer gease seals in pairs as well. Is this per side, or per vehicle?
4) Besides the whole shipping grease/operating grease knowledge, is there anything else I need to be aware of? Thanks in advance!
Clarke
Old 01-23-2005, 09:33 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
I'd say about 250-350 should be a fair price for each side.
Lwin M. Maung (Member # 147)
Current SVX: • NONE
Other current cars:•2001 Jeep Grand Cherokee Black
Old 01-23-2005, 09:34 PM
There is 2 per side. An inner and an outer bearing. That is why there are two seals as well.
Good luck.
Old 01-23-2005, 09:35 PM
Invisible avatar
Cool
Since you don't have time to shop around, expect to pay a dealer $100+ bucks for ONE bearing, plus about $20 for TWO seals & a few bucks for a new axel nut. I had an independant mechanic install all for $210.00 (mid-Atlantic prices), last week on mine.
There's plenty of do's & don't's in here when you around under "wheel bearings".
Good luck - Ron.
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 01-23-2005, 09:42 PM
clarkerussell
Good luck.
I obviously don't understand how the bearings function on the car...
So to do both rear wheels I'd need a total of 4 bearings, 4 inner seals and 4 outer seals? Are the bearings all the same? Thanks.
Clarke
Old 01-23-2005, 09:44 PM
clarkerussell
Good luck - Ron.
So that'd be $120 for parts and another $200-$300 for labor? Thanks.
Clarke
Old 01-23-2005, 09:48 PM
clarkerussell
Good luck.
Clarke
Old 01-24-2005, 03:06 PM
oab_au oab_au is offline
Clarke
Hi Clarke, the bearing has a double ended outer track, with a tapered roller race in each end, thats three pieces of bearing, plus an inner seal and an outer seal for each side.
So you need a compleat bearing and inner/outer seals for each side.
They make a lot of noise, but when you get them out, the track only has a small amount of marking on them. I have not heard of a bearing breaking up.
One Arm Bloke.
Tell it like it is!
Old 01-24-2005, 11:32 PM
the plastic casing on my bearings was broken but all my rollers were intact and not too worn. You could prob make the trip back without doing them if you really needed to, just beware of the noise. anyway have a rebutle for my statements feel free
Old 01-25-2005, 12:41 AM
LOOOOOOOOL, send me your whole rear axle over here, I will do it for you for $100 .... only.
Old 01-25-2005, 09:44 AM
red95svx
Rear bearing set up:
complete bearing assembly: 28016PA010. Subaru list= $78.02
inner seal: 28015AA070. Subaru list=$8.83
outer seal: 28015AA021. Subaru list=$10.70
Total parts, one side: $97.55
You may or may not need additional parts, but at least you know what Subaru "offficially" charges for the main parts.
EDIT: Harvey is right. We've seen some VERY bad bearings before, but I've never heard of one completely failing.
Old 01-25-2005, 09:56 AM
red95svx
Good luck.
Yes and no. The bearing does have multiple parts, but they are only sold as whole assemblies. So there is only one per side, plus one seal one either end. Subaruparts.com is trying to sell you both sides at once.
Old 01-25-2005, 10:02 AM
red95svx
Just checked out Subaruparts.com. The default setting is for two bearings to be added to your order when you click on rear bearing. You can manually change the quantity though so that you can purchase just one bearing (one side).
Old 01-25-2005, 10:53 AM
dcarrb dcarrb is offline
Probably safe to say that if the bearings on one side are failing, the other side's not far behind.
dcb
Old 01-25-2005, 11:12 AM
you should be able to pick up a set of aftermarket bearings at a local parts deal like a NAPA or something like that for a similar price. I order mine from NAPA and got them the next day. cost me 180 for both side with bearings and seals.
