Old 09-12-2002, 07:15 AM
svx_commuter's Avatar
Rack Part Number
Is the part number for the road speed sensitive rack the same as the engine speed sensitive rack?
Old 09-12-2002, 08:38 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Rack Part Number
I should think so. I believe the "speed sensitive" components are more tied to the pump, than the rack. The parts catalogue only lists one part number for the rack (34116PA000), but, lists separate part #'s for LS and LS-L models for Gear assy, pinion, housing and pump. Also lists separate numbers for oil pressure feed tubes, both upper and lower.
Randy Johnson
Mike Davis -- at Reading VI
Old 09-12-2002, 01:33 PM
Randy,
Thanks for the reply. So I guess if I (or someone else) look(s) in the SM, there will be a different control circuit for the two types of racks.
Old 09-12-2002, 05:10 PM
Aredubjay's Avatar
Randy,
I would reckon, but, it's only a reckon. I don't want you to reckon account o' me.
Randy Johnson
Old 09-12-2002, 06:45 PM
dromano's Avatar
dromano dromano is offline
rack
[QUOTE]Originally posted by svx_commuter
Randy,
[/QUOT
John,
Please post the good, bad and ugly of replacing the rack. When I was under there looking at stuff, the rack looked like a tuff item to get out of its home.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 09-13-2002, 03:47 AM
Trevor's Avatar
Trevor Trevor is offline
Has anyone seen a quick rack listed anywhere for the SVX ? I.E. to give higher geared steering.
Trevor, New Zealand.
Old 09-14-2002, 06:15 PM
Trevor,
I have not seen a quick rack. I hope you find one.
Everyone else, the Service Manual shows a different rack for the electronic speed control LS-L as opposed to the engine speed type. The rebuilder I talked with says there is only one part number. My rack is okay. I am just trying to find a used one for future use.
See the SM section 4-3, page 25, figure 30.
Old 09-14-2002, 06:52 PM
Trevor's Avatar
Is there an equivelent rack used by another manufacturer, i.e. is this a Subaru only manufactured item ? In all probability it is not although there may be some small differences which could be modified.
I also have in mind that a quick rack is fitted to the SVX full rally versions. For those wanting to DRIVE QUICKLY upping the steering gear ratio is a no, 1.
