K & B spring rates
anyone know the spring rates of the k&b springs that dayle has???do the struts and springs that dayle sells require any welding or special modifications like the koni/gc??just curious..thanks for any help
Not sure but I think they are about just like the Ground Controls... Yea, they will probably require welding unless you can find a company that makes kits with K&B springs....
2020 Subaru Outback Touring - Wife's first Subaru 2005 Volvo V70R - 5-cylinder love! :Heart: ** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned ** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!! ** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love... |
so is the koni/gc setup probably better then???
That's the setup that I've herd the most about... I'm trying to be a lone ranger though and am still hunting down Aragosta.... I'm gonna get what I want from them!!!!
The K&B don't require any cutting or welding... they are a direct replacement for the stock springs.
The Ground Control kit is using a universal fit spring, that's why you have to cut/weld the strut housing, and it must be used with Koni struts. The K&B can be used with the stock struts just fine... so the K&B is a much cheaper alternative. A full Ground Control / Koni setup will run you about $1000 just for the parts. |
so what if one was to get the k&b springs and then koni struts would that be a decent upgrade or no???not feasible???thanks for any help
I have the Koni struts and K&B springs and it was a great upgrade. It lowers the car and it corner far better than when it was stock.
did you install them yourself???if so how hard of a job was it???thanks for any help...
Sorry - they were already installed when I bought the car.
Re: K & B spring rates
http://www.sissk.co.jp/kbsports/subaru/subaru.htm The spring rate is somewhere between 10 and 20% higher. They are in a completely different realm than the GC springs which are about 250% stiffer. As the other people said, they are a drop-in replacement for the stock springs and will work fine with the stock struts.
