*** Doing Rear Subframe Any Pointers ***
Bought most every bolt, washer, bushing, nuts and caps OEM
SSP should provide Rear subframe with trailing arms Going to ask for support plates New calipers Hopefully sway bar and brackets * Now as far as I know the frame is bolted to the body The axel shafts shouldnt have to leave the diff Nor the gas tank -prob use ramps, jack stands, etc. Do I have to remove the exaughst ? Will I need any special tools ? Do the bearings have to be pressed into hubs ? *Can I use clamps to rewind calipers and does proportioning valve need to be reset Pnuematically if reservoir goes empty ? Any knowledge would be welcomed thanks Tommy 1996 LS-I -Polo Green - #467 |
