Old 05-30-2007, 08:35 PM
JIMSVX's Avatar
JIMSVX JIMSVX is offline
.... what a sweet ride !!
Driver's window auto up & Down
I need to start troubleshooting my driver's window switching. My auto-up works most of the time, but the auto-down doesn't work at all. Can anyone explain to me how this function is implemented on the SVX? Is it done in the driver's door switch assembly, or is it in a circuit located somewhere else?
Thanks
- Jim
'02 Outback - Wife's car
'96 Legacy Wagon - Son's car
'95 Legacy Sedan - #5 Daughter's car
'93 Impreza Sedan - #4 Daughter's car
'92 Claret LS-L - My car ____________
TOTAL = 595,000 Subi miles
Old 05-30-2007, 09:48 PM
It is done in the switch itself. If you change the cluster to a different one that is from a later model, it will not have the auto feature in it.
Old 05-30-2007, 09:54 PM
JIMSVX's Avatar
Thanks Earl.
Now my second question, has anyone successfully repaired the switch assembly? I have searched, but found nothing.
- Jim
Old 05-30-2007, 10:16 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
im pretty sure no one has... i guess it just hasnt buged people enough to fix it
- John
Old 05-30-2007, 10:36 PM
If you mean repair the switch if it is broken, someone has. They are no longer here, but they figured out how to do it. I don't know how, because they would not share the secret. They were fixing them and charging for the repairs. I have a couple that are broken and I have not had a chance to try the fix yet.
Old 05-30-2007, 10:51 PM
JIMSVX's Avatar
Well, I guess I'll give it a try. I have to tear my doors open to install new speakers and clean the window felt pads. So in the process I'll see what the switches look like. At least I know they have been repaired, so it is possible.
Thanks!
- Jim
Old 05-30-2007, 11:19 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
It will still have the auto down feature but no auto up after 94....!? Am I correct?
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 05-31-2007, 05:57 AM
dcarrb dcarrb is offline
A new '92 master switch does still have auto up/down (I just installed one Saturday), which seems a bit surprising if they dropped the auto-up after '94. Auto-up was a safety issue, to be sure, especially for kids.
Curiously, the pivot points on all my switches were broken, EXCEPT the driver's. One would think it the other way around.
dcb
Old 06-12-2007, 08:07 PM
Earthworm's Avatar
Meow!
The driver was the only one smart enough not to apply too much pressure to the switch. (Either that or it was already replaced)
Old 06-13-2007, 12:04 AM
dcb
I think that the 92 and 93 years were the only ones with the auto feature.
Old 06-13-2007, 06:15 AM
my 97 has auto-down.
Old 06-13-2007, 06:16 AM
more importantly, neither auto-up or auto-down work in the 92.
Old 06-13-2007, 03:51 PM
It's Just Eric's Avatar
Missing in action
92-93 had auto up and down. 94+ had auto down only
Earl...Either you're wrong, or every one of your window switches is broke
R.I.P Cool Signature.
Old 06-14-2007, 05:38 AM
JaySVX's Avatar
JaySVX JaySVX is offline
I repaired the assembly in my 94, it was actually quite easy/simple. 99% of the time it's the holder. The key test is if you remove the switch(top part), you see two little white buttons. If they still function properly, i can show you how to easily repair it. If not, i'll see if i can tear mine appart this weekend to see how it works. Let me know on those two white switches, and be aware that the rear window switches in the driver's console are different than the front, for some odd reason. The 4 switches have a different setup, and mounting, so it depends on which one you would like to repair on how you go about it.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 06-14-2007, 06:30 AM
No; I meant, of the four switches in the driver's door master unit, the driver's was the only switch that wasn't broken. That struck me as the opposite of what would be expected wear. Or come to think of it, maybe the auto up/down feature takes credit, as it works with just a click while the other switches require constant pressure.
dcb
