Engine re-installed, no start
Ok, so the engine came out for head gaskets, dropped the engine back in and hooked everything back up. It all goes smoothly. Get in the car, cycle i on and off a few times, unhook the ignitor and crank it a few times, hook it back up, and hit the starter. It turns over and fires but is running very rough so I shut it off. Since then I haven't gotten any sign of life out of it, not even a sputter. Has fuel and spark but won't catch. Tried a little bit of starting fluid but nada. Double checked all the sensors but they're new and hooked up correctly?
Anybody have any suggestions? |
Re: Engine re-installed, no start
Definitely have spark. Pulled the plugs just to check because I was thinking the same thing. I thought about a possible timing issue too, I just wanted to run it by the network to see if they had any ideas.
Secondly, after installing the belt and releasing the tensioner pin, you rotated the crank a revolution or two and verified the marks all still lined up? It would just seem that maybe your timing is off a couple notches or more. |
I'm not the one that did the head gaskets or the timing. I shipped it to a local subie shop for that. I just did the pull and re-installation.
I'd say timing as well, but the only thing is that the few cars I've seen with the timing off still spit and sputter a bit. This thing is just turning over and over. |
Update:
The timing covers are off it, and magically, the timing is dead on ![]() ![]() |
You checked it? Or the shop said they checked their own work and it was ok?
Unfortunately cranks/no-start can be a real PITA to diagnose..... id start by going over your engine inch by inch looking for an unplugged or broken harness or vacuum hose. 9 times out of 10, when something is wrong after a repair, you simply forgot or borked something during that repair. |
They pulled it apart an I looked at it. Double checked spark and fuel too.
They're going over it right now, so hopefully I'll know what it is by the end of the day. |
Ok, results are in. It somehow flooded itself. Changed the plugs and it fired and ran, but there were a couple messed up vacuum lines that were causing all this misery and an idle issue it had before.
Cool, glad you got it started. You did replace the lines this time around then yes? If you have a fat vacuum leak the ECU will dump more fuel into the cylinders to compensate for the "lean" mixture.... which can flood it and will foul the plugs.
I'm not the one that found the split line, so I'm not sure where it is. I had an IAC issue before too that was causing issues as well.
