Old 07-26-2008, 03:33 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
struggling to reset c/e code
Just replaced an O2 sensor..had a 32 code and I tried both ways to reset the code:
1) placed both pins in upper left 1 and 2 pinholes, started car, shut car off, removed one pin and then turned car on but not starting it....to read the blinks.....error still there.
2) with pins removed , turned car on but not starting it, turned on headlights, then disconnected the neg. batt. cable.....and waiting about 30 secs.... then proceeded to turn lights off, take key out, connected batt. cable, stuck pin in second hole on upper left and proceeded to check the codes again.....no luck still old code in there.
I did let the car run until normal op temperature, but haven't driven it around yet.
Can someone tell me why this issue I cannot resolve?
thanks
1995 Subaru Svx L / AWD
Old 07-27-2008, 05:43 PM
msvx95's Avatar
It's just a phase
Re: struggling to reset c/e code
bump....anyone know how to resolve this?
I drove the car and no issues last night...no c/e light on dash, I just can't erase the old code
Old 07-27-2008, 06:53 PM
ShiuludeSVX's Avatar
ShiuludeSVX ShiuludeSVX is offline
Send a message via ICQ to ShiuludeSVX Send a message via AIM to ShiuludeSVX Send a message via Yahoo to ShiuludeSVX
Draining the system should take care of it, unless there is in fact still a problem.....
Pull the negative cable.
Turn the key to full on, but not start.
Turn on the headlights {only takes a second}.
Hook it all back up and check for codes.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 07-27-2008, 07:18 PM
redlightningsvx's Avatar
Collision Refinishing Tech
disconnect the negative terminal all night and reconnect it in the morning and it should be gone
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 07-27-2008, 08:55 PM
kwren's Avatar
kwren kwren is offline
This was the only way I could erase the codes on mine.
(also helps if the problem doesn't still exist)
Keith
Old 07-28-2008, 06:32 AM
msvx95's Avatar
It's just a phase
Keith
Yes I did try this 3 or 4 times and didn't work.
I will try redlightningsvx suggestion leaving it disconnected overnight. I can't think of anything else to do.
Old 07-28-2008, 03:48 PM
kwren's Avatar
Problem may not be corrected...
I left my battery disconected for a week and nothing eraced till I got the problem corrected. I had a 37 code, replaced the 02 and did not correct the problem.
After I got it corrected, tried the 2 blue wire thingie... did the battery disconnect thing...
Did the battery disconnect, turn ignition switch on but did not start engine as per instructions (how am I going to start the engine with the neg battery cable disconnected)
next step headlights!
Hope you get it worked out ok!
Keith
Old 07-28-2008, 05:19 PM
This is how I was able to clear my TPS code and both o2 codes
Seth
Past subies:
Other toys:
Old 07-28-2008, 05:51 PM
kwren's Avatar
Battery disconnect is how I cleared my codes many times but sometimes, because of various conditions, some codes are harder to clear.
Keith
Old 07-28-2008, 10:54 PM
Keith
hahhahaha....... you so funny Joe.....Buy me drink.
Didn't say it would start, but meant to the full on position.
This will usually do the deal, because it forces the system to give up any residual energy to the headlights.
The advantage, is that you don't have to wait more than 1 second for it all to go away.
The Worm
_______________
No Mods, 33K Miles
Old 07-29-2008, 12:15 AM
kwren's Avatar
Old 07-29-2008, 12:17 AM
kwren's Avatar
Seriously, is great information... Much appreciated
Keith
Old 07-29-2008, 05:17 PM
msvx95's Avatar
It's just a phase
Ok, Redlightningsvx was correct for what he told me...it worked....got the steady blinks which means good.
I will post again to see if someone can add to the How-to's
Old 07-29-2008, 06:11 PM
Keith
Welcome. I'm glad you got through it.
I'm sure we all hope it continues to run well.
Side note... Just met a local Mini Coop driver that used to hang around with a few SVX-ers a while back.
He recognized the car right away, and told me all kinds of "Old Timer" stuff about his experiences with our cars.
The Worm
_______________
No Mods, 33K Miles
