Old 11-21-2013, 08:07 AM
Subie59's Avatar
Subie59 Subie59 is offline
94 SVX LSI Teal
A little knowledge is a bad thing -screwed up need help
Ok guys. Drivers side window went down, now it won't go up. Did a search found out you could put two wires on 12 volt drill battery and, depending on how you put the wires +-, the window goes up and down by bypassing the window controls.
Took the skins off found what looked to be the right clip (and inserted wire) attached to battery sparks and strong acrid smell of burning electricity near passenger side. oh oh
Checked the battery and notice it's 14Volt lithium not 12 volt. Now motor on passenger side does not seem to work.
Question: did I burn a motor (probably) or just a fuse???
Car is in service station now to get window up because it's going to rain..
Should have taken it there from the first place damnit
94 SVX LSI
2001 LegacyGT (daughter's ride now)
2005 Legacy outback XT (wife's car)
all stock and likely staying that way for now
1981 Datsun 280zxturbo summer toy
Old 11-21-2013, 10:30 AM
Re: A little knowledge is a bad thing -screwed up need help
sounds like you just chose the wrong 2 wires. your car voltage is around 14v when it is running. hopefully you just blew a fuse.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 11-21-2013, 02:51 PM
svxcess svxcess is online now
That's probably what happened.
My electrical puts out 14.5V at startup every morning and has a normal operating voltage between 13.6-13.8V. Never an issue with electrical components. You shound be fine.
Most modern alternators put out between 14-14.6v to charge and maintain your 12V car battery.
Old 11-22-2013, 07:40 PM
Subie59's Avatar
94 SVX LSI Teal
when it rains it pours. ok service station got the window up $122 later. Robbery but what are you going to do. Do tonight when I went to go home from work car would not turn over enough to get it going. A couple of weak cranks and it's dead. Got a boost but on the way home I noticed that the door light on the passenger side was on and would not shut off. No doubt the reason why my battery died. pulled the lightbulb after trying everything to get the light off. I can't imagine that touching those two wires with the battery (on the drivers side of the car) could have caused that problem but I can't figure out anything else....
94 SVX LSI
Old 11-22-2013, 08:48 PM
I have a feeling you may have done some damage to the time control unit, located behind the glove box. Are any other lights acting normally (keyhole illumination, dome light, map lights, under dash footwell lights, etc) which normally go out after a set interval, affected?
Old 11-23-2013, 06:14 AM
Subie59's Avatar
94 SVX LSI Teal
No I have not noticed any problem with the other lights. Dome lights seem to work fine. Not sure about the foot lights but they are not staying on. When I pulled the door light everything was dark last night. BUT that burning smell I was getting certainly smelled like it was coming from the direction of the glove box or at least that side of the car. So maybe you are right.
94 SVX LSI
