Old 09-28-2009, 04:21 PM
Jvan Jvan is offline
Question replace plastic lever for remore trunk release
The top of the plastic lever cover broke so that it can't hold the cable to release the trunk lock. I have an entire remote trunk/gas door unit and I had planned on replacing the entire unit. However, I think I can just remove the plastic lever from the new unit and install the old cable into the new lever. Does anyone know how to remove the plastic lever? Does it just snap onto the metal swing arm? I don't want to break the new plastic lever just trying to prying it w/knowing what I'm doing.
Old 09-28-2009, 05:09 PM
kwren's Avatar
kwren kwren is offline
Re: replace plastic lever for remore trunk release
just pull it off
Keith
Old 09-28-2009, 05:50 PM
redlightningsvx's Avatar
Collision Refinishing Tech
You can't just pull it off, their is a small allen head bolt on the underside of the lever.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 09-28-2009, 09:20 PM
Banned
mine just pulled off on my 92...
Old 09-28-2009, 09:32 PM
Iy doesn't just pull off. I tried that first because the plastic cover for the gas door did just pull off. I'll look for the allen screw but I didn't see when I first looked. I though that it might just have some type of clip that needed to be released.
Old 09-28-2009, 10:11 PM
It looks like it just pulls off. I don't see a reference for a screw.
Old 09-28-2009, 11:59 PM
Banned
ya I've taken mine off a few times, it didn't ever have a screw or anything only screws were to hold the outside part to the car not the actual tabs. Those are located one under the lever and one inside a little covered compartment on the back you get to by popping off the cover with a flathead. maybe they changed it in later years.... speaking of these though I lost the little one anyone have an extra? I might just go to a junk yard and grab one.
Old 09-29-2009, 02:28 AM
I have a full extra assembly, what exactly do you need?
Old 09-29-2009, 10:46 AM
I didn't see any screw but it doesn't just pull off. There must be a clip that is holding the plastic but I don't see where to pry it up to release the plastic. The gas door plastic did just slid off but I slid it back on and it also is now unmovable so there must be some thing holding them. I will have an extra gray gas door handle when I'm finished which you are welcome to.
Old 09-29-2009, 08:22 PM
kwren's Avatar
mine 2................
Old 09-30-2009, 04:15 PM
I don't know if they changed it during the years but mine has a very tiny allenhead on both the trunk and fuel lever on the bottom most part of the handle. It's really hard to see.
Seth
Past subies:
Other toys:
