Old 02-26-2021, 07:50 AM
Huskymaniac's Avatar
Uses the ignore feature
Spark Advance
What is normal for idle and at around 2500RPM cruising on the highway, level ground?
Tony
Old 02-27-2021, 04:09 PM
oab_au oab_au is offline
Re: Spark Advance
Well if you are talking about a SVX, its about,10* to 20* BTDC at idle, it changes around to control the idle speed.
Light throttle cruise about 55* to 65* BTDC, when the pedal is on the floor would go to about 34* BTDC.
One Arm Bloke.
Tell it like it is!
Old 03-02-2021, 04:54 AM
Re: Spark Advance
So, correct me if I am wrong but 50 degrees while cruising would indicate that there is NOT a knocking problem, correct? The number goes up if knocks are sensed, right?
Tony
