wtb plug that goes into fuse box
I'm looking for one of the plugs that goes into interior fuse box. It's the plug that goes into the front bottom socket in the fuse box. It has a black and red wire, a blue wire, a red wire, and a white with black strip wire. Close to the plug the wires will have a label with a harness part # on it that is: 81201PA110. I'd like the wires cut just past that label so I get the plug and a length of wires with the label attached.
http://www.subiechips.com/posts/need...427_190810.jpg http://www.subiechips.com/posts/need...427_190801.jpg http://www.subiechips.com/posts/need...427_164151.jpg |
Re: wtb plug that goes into fuse box
doobie doobie dooo
I'll nab it off the SVX for you in the nearby junkyard next time I'm out there.
1992 Dark Teal LS-L w/ 165k+ miles (traded ) Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs 2001 Black Toyota Sequoia (hauler/daily) 1992 Blue Toyota Cressida (drift car) 1992 Red Toyota MR2 (weekend/track day car) |
That would be great! Thanks. If it has the trunk side interior pieces and or an lsi headliner I'm looking for those too. You can be a upick part reseller
