Old 05-03-2003, 08:18 PM
SVX JAZZ's Avatar
SVX JAZZ SVX JAZZ is offline
Tired
Power Steering, how it works?
My power steering has been working well for the past week since I fooled around with the sensor near the power steering pump. What does this sensor do? No dash lights lit up when I un-plugged it. Mine is a 92 with speed sensitive steering. It has never seemed that speed "sensitive" though. How does the speed sensitive steering work? Does the pump vary it's pressure?
I would like to know why the binding in my steering simply went away. I do not belive it is a rack problem now. Racks don't usually just get better.
Thanks!!!!!
Paul
1992 LSl (Black Mica)
1965 Mustang G.T. Fastback
1990 Mustang G.T. Convertible
1986 1/2 Nissan 4x4
2004 Vovlo XC70 (wife's)
Wonderful Wife
Wonderful Son
2 Cats
Incredibly blessed!
Old 05-06-2003, 05:55 AM
svx_commuter's Avatar
That is great the binding went away. It may have something to do with temperature. Have you changed the fluid?
The PS system workings? If I get time I'll look in the FSM.
Old 05-06-2003, 06:31 AM
SVX JAZZ's Avatar
Tired
Yeah, I changed the fluid and added an additive (per huck). It still did the binding. The temp was cool when it first started acting up but it then as the days went on it warmed up around 80 but was still binding. Last Saturday I degreased the bottom end of my car (due to leaking cam seals, blown radiator hose and dripped power steering fluid). It cleaned up real well. Later that evening I unpluged the sensor that is located near the power steering pump. I drove it around and the steering came back to life. I don't know if it was the cleaning or the sensor. I am not sure what that sensor does. I pluged it back in and it has been fine. Sunday there was a slight binding on the way to church but nothing extreme.
Thanks,
Paul
Old 05-06-2003, 09:00 AM
tlemmons
I also have a 92. How do you know whether it has speed-sensitive steering and also which type. I have seen references to a couple of different type of steering systems. Are there any descriptions on what is different or how each works.
Old 05-06-2003, 09:06 AM
SVX JAZZ's Avatar
Tired
I am asuming it's speed sensitive since it is an LS-l, loaded with all options. It lossens up when I slow down and tightens up on the road at speed. Sometimes though, it's tight when I am driving slow. I guess it's sometimes speed sensitive.
Thanks
Old 05-06-2003, 10:24 AM
alacrity024
my power steering has been cutting in and out.. it primarily cuts out when the car is still cold.. once i drive around a bit, things start to feel fine.. but i get a stiff wheel and a bunch of christmas tree lights when i try to turn the wheel right after starting it... i checked the belt and it's not slipping or anything
-adam
Old 05-07-2003, 05:15 AM
The road speed sensitive rack has an electric module on it with a wire going to it. The engine speed sensitive rack does not. If you look below the steering shaft you can see the top of the rack.
Old 05-07-2003, 05:55 AM
Re: Power Steering, how it works?
Thanks!!!!!
When I added the Lucus additive to mine, I drove it a couple miles and it didn't seam to help...so I parked it, and about a week and a half later, I went out and it worked perfect....and has ever since.
The Last thing I did was add the additive, so I'm assuming that is what got it going, it might take a while to work in
Either way I'm just glad it's working
Old 05-07-2003, 06:55 AM
SVX JAZZ's Avatar
Tired
Re: Re: Power Steering, how it works?
Heck Huck... It might have been the aditive that worked. Nothing changed after I first added it, but 4 days later the steering cleared up.
I am going to put that stuff in my stang and truck. Good stuff.
Paul
1986 1/2 Nissan 4x4
Wonderful Wife
Wonderful Son
2 Cats
Incredibly blessed!
Old 05-07-2003, 09:56 AM
LarryIII LarryIII is offline
Here's what I know about how it works. You turn the steering wheel. That causes the front wheels to turn in the same direction as the steering wheel. I didn't say I knew alot.
I took the condensed Box-O-Tech course given at the RM Auto Mechanics & Clear Plastic Slip Cover School located in Maryland.
Old 05-07-2003, 10:18 AM
SVX JAZZ's Avatar
Tired
You're kidding!!!!!
That sounds like the same kind of trining we get, or should I say "git" down here in NC.
Old 05-07-2003, 08:44 PM
lee lee is offline
I tried to sign up for their "How to steer when you're backing up with a trailer" class, but they took one look at me and started laughing. I never could figure that out.
Old 05-08-2003, 05:05 AM
Hey guys. Just for the record, what is the name the additive goes by? Is it a Lucas power steering additive? I have used a Lucas a/t additive. I am not sure about the results. It doesn't help the 2-3 flair.
Old 05-08-2003, 05:38 AM
The bottle is at home, but I think it's the only "Lucus" brand that is for power steering.
Old 05-08-2003, 06:00 AM
SVX JAZZ's Avatar
Tired
Yeah, Lucas Power Steering aditive. I think it also says something about "stop leak" as well. It's a white bottle with a funny tip, almot like a squeeze bottle.
Paul
