Old 08-02-2002, 09:18 AM
anthonybuchanan anthonybuchanan is offline
Does air conditioning compressor go on and off
I have always wondered what the air conditioning compressor does when the temp setting is raised from 65 to 72. Does the compressor keep working strong well warm air is mixed in with cold air or, does the compressor shut down (saving gas) until the desired temp is reached and then start working again.
Old 08-02-2002, 09:46 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Does air conditioning compressor go on and off
The compressor on the SVX does not "cycle" as it does on most cars. I posted a quote from the manual . . . somewhere in my 5,000 some-odd posts. You might do a search on compressor. Or, if you're "brave" you could click the "view all posts by this member" button.
Randy Johnson
Mike Davis -- at Reading VI
Old 08-02-2002, 09:55 AM
Aredubjay's Avatar
Awww, what the heck. I did the search for you. Here's what I posted in my previous post:
Okay, here's a quote from the manual:
"4. Air Conditioning System
1. Compressor
1) General
A wobble plate electronically controlled variable delivery compressor is used. The solenoid valve built in the compressor is controlled by the auto control unit. This ensures optimum compressor delivery with less power and less fuel, as well as smooth drive feel since ON-OFF is eliminated."
Randy Johnson
Old 08-02-2002, 11:01 AM
jscorse's Avatar
jscorse jscorse is offline
Send a message via Yahoo to jscorse
...and....AND
If you stomp on the pedal and activate POWER MODE, the A/C will cut out for you to give those wheels all the power they deserve.
I wish they would have done that with the Forester. The poor little four banger practially stalls when the A/C kick in and out....
Jeff
'97 LSi, Ebony Pearl, LSi, 155K
